Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
I have a bj7. I live in iowa where summer temperature averages between 70-90 degrees. What is the correct weight of oil to use? I have been told at auto parts store to use 10-40. Is this appropriate?
What is the condition of your engine? If it is freshly rebuilt with tight (on spec) clearances 10-40 would be fine. If it is well worn (100,000 miles) like mine, I use 20w-50.
20/50 is what was recommended. I stick with Classic versions of that, such as Castrol, Millers, Penrite etc. Don't use the thinner, modern oils they are created for completely different engine types.
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
