Oil pressure gauge -on 1978 Mg midget 1500
jbuffalo
How do you install a oil presure gauge on a midget without one. What parts do I need, is it best installed under the dash? I see a large brass bolt on the top of the oil filter housing-is that where it starts? thanks Jim
i bought an after market gauge, on a whim at the local auto parts one day. It came with all the stuff needed to install it. I was kinda surprised it fit with having to find any special adapters. it hooks to the hole in the pic referenced above. just unscrew the warning lite sensor and hook your gage to the same port.
mark
Mike H
I put a dual gauge in my '78. I replaced the single temperature gauge in the dash. I removed the sending unit from the block, inserted a "T" and then redid the connections. I now have a working gauge and a warning light.
Blueghost
Warning light with PSI gague is only way to go. How many people really look at oil PSI all the time? None. Warning light jumps out at you much clearer when needed. However, warning light (idiot light) doesn't predict anything. Nice to know if PSI is actually dropping below 20 when hot at a red light.
Blueghost
jlaird
I watch the oil pressure till I am convenced that all is ok. Just scares the heck out of me to loose pressure.
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
L Oil Pressure Gauge Austin Healey 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
S TR2/3/3A Oil pressure gauge removal Triumph 11
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
L Wanted WANTED: good Working Oil Pressure GAUGE Triumph Classifieds 0
K TR2/3/3A Oil pressure gauge needle sticking? Triumph 4
K TR4/4A Oil pressure gauge Line? Triumph 5
6 General Tech Installing New Oil Pressure Gauge MG 5
6 Installing Oil Pressure Gauge Spridgets 2
Superwrench Oil Pressure/ Water temp Gauge Austin Healey 17
JimTR4 TR4/4A Oil pressure gauge hose Triumph 5
T Oil Pressure Gauge Not Reading Spridgets 8
B TR6 Oil pressure gauge-oil leaking behind the glass Triumph 2
K TR2/3/3A Oil pressure gauge readings? Triumph 9
M TR2/3/3A Oil pressure: the gauge? Triumph 4
Rut MGB Oil pressure gauge leather washer MG 13
Geo Hahn TR6 Oil Pressure Gauge Triumph 4
maxwedge5281 oil pressure gauge line...urgent!!! Austin Healey 10
K TR2/3/3A Oil pressure gauge indicator needle sticking? Triumph 10
PatGalvin TR2/3/3A Oil Pressure Gauge Leak - Leather Washer? Triumph 12
M TR2/3/3A Reading oil pressure gauge Triumph 3
K GT6 Spitfire oil pressure gauge readings? Triumph 4
pkmh Reinstalling oil pressure gauge in a BJ8 Austin Healey 4
P Mounting Bracket for Bugeye, Water/Oil Pressure Gauge Spridgets 5
NardisCNC Oil Pressure Gauge Questions..... Spridgets 8
JimTR4 Electric oil pressure gauge Triumph 20
Dougal BN1 Safety Gauge [oil pressure/water temp] number Austin Healey 4
T Oil Pressure Gauge braided line failure Austin Healey 6
S TR2/3/3A TR3A Oil Pressure Gauge Leather Gasket ?? Triumph 11
D Oil pressure gauge flex hose. Spridgets 29
Stewart Removing the rectangular oil pressure gauge MG 5
sail Oil Pressure Gauge Stuck Triumph 4
60TR3A Leaky Oil Pressure Gauge Triumph 14
E Oil Pressure Gauge Pipe Fitting Spridgets 7
E Bugeye Oil Pressure Gauge Spridgets 5
tmc oil pressure gauge and line Triumph 5
The_architect oil pressure gauge lines: steel vs copper Spridgets 8
hondo402000 TR6 TR6 71 Oil pressure gauge Triumph 3
R Oil Pressure Gauge MG 3
W Oil pressure pipe - gauge to flex hose P/N 2A5640 Spridgets 10
RedTR3 TR2/3/3A TR3 Oil Pressure Gauge Hose Triumph 3
T 1500 oil pressure gauge leaking Spridgets 6
RickB Oil pressure gauge scared me last week... Spridgets 3
M Oil Gauge reading high pressure MG 3
RickB Dual temp / oil pressure gauge - how to remove? Spridgets 18
Atrus Oil Pressure fitting thread size [calibrate gauge] Spridgets 15
