Oil pressure gauge flex hose.
David_Doan
My Bugeye had a small hose connecting the oil pressure line from the engine to the oil pressure line comming from the gauge. It failed and I replaced with a piece of vacuum line. That did not last long. Local auto stores do not stock fuel line that is small enough (1/8" I think).
Moss lists the part as - <span style="font-weight: bold">361-765 HOSE, oil pressure</span>- for $16 plus shipping.
Is there a easy-to-find alternative that will hold up to 60 PSI?
Thanks,
David
Morris
You can pick up a nylon oil pressure hose and fitting at your local parts store for $7-10.
Billm
Easiest way is to go to Harbor Freight and for $13 but one of the "3-gauge" sets that come with mechanical gauges (all of them do) and then just use the oil pressure adapters and hose that is in the kit and then throw away the gauges (or keep them as backups).
BillM
David_Doan
Thanks for all the tips. I did buy one of the nylon hose kits, but I decided to try one other solution 1st. The parts store suggested small engine fuel line. It is small and flexible but not reinforced. It should handle 60 PSI OK but it didn't seem sturdy enough to last. Then I thought of sliding regular fuel line over it as reinforcement. Standard fuel line fit perfect. So far it seems to work fine and looks somewhat original. If this fails again I will switch to the nylon tubing. Some pics below.
dklawson
Did the original metal pipes not have a ferrule (olive) on the ends so the factory hose would grip better?
smaceng
My BE had ferrules on the short copper tube attached to the engine and to the copper tube passing through the firewall. I used a rubber type tube (bought from Moss if believe) which I pushed over the ferrules, and then uses tubing screw clamps to hold it all together. No leaks yet, except when I reinstalled the engine and forgot to hook up the oil line.....what a mess....Homer strikes again and I saw him in the mirror!
Scott in CA
jlaird
Both ends have ferrules close to the ends to secure the hose behind the clamp.
I just happen to have a new/old set on the workbench and went and checked.
The original hose was black of course and had a kind of knitted wrapping on the outside. Was about a foot long.
HAN8L1965
Do not use the small engine fuel line, it will heat and burst, how do I know that? What a mess and it almost drained my 1098 before I noticed. I would buy the hose and clamps from Moss or VB as it is necessary everything fits good and tite on these very small connections. I tried others, they to failed.
Mark
Jim_Gruber
I discovered the hard way the first time I started Bugsy that the DPO had neglected to connect the Oil Pressure Line to anything. 20W50 at 70 psi can create quite a mess squirting sideways and going into the PS footwell via the clutch slave access panel. After about a Quart had shot sideways into the Passenger Footwell I discovered the problem and shut things down. Talk about a mess to clean up.
I suspect that solution will hold for a long time.
A hydraulic shop might have a hose small enough to work.
Boink
Bronze
Hey, let's start a pool. I give it 125 miles tops.
:highly_amused: A pool. LOL
I'd probably run a completely new line (with nylon and conventional compression fittings - used to have this in a Mini I had).
PeterC
The nearly perfect off-the-shelf line is diesel fuel return line from most Audi VW cars and parts stores. 3mm re-enforced cloth covered. Not as thick as the original, but more than up to the task. Team up with 3 friends and splurge on a foot.
Peter C
Or buy a foot and sell two "kits" on ebay for $20 each. :smile:
bobhustead
Are you off your meds? Get the proper hose from moss or wherever and avoid an engine fire, an engine seizure, a roadside stranding.
Bob
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
L Oil Pressure Gauge Austin Healey 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
S TR2/3/3A Oil pressure gauge removal Triumph 11
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
L Wanted WANTED: good Working Oil Pressure GAUGE Triumph Classifieds 0
K TR2/3/3A Oil pressure gauge needle sticking? Triumph 4
K TR4/4A Oil pressure gauge Line? Triumph 5
6 General Tech Installing New Oil Pressure Gauge MG 5
6 Installing Oil Pressure Gauge Spridgets 2
Superwrench Oil Pressure/ Water temp Gauge Austin Healey 17
JimTR4 TR4/4A Oil pressure gauge hose Triumph 5
T Oil Pressure Gauge Not Reading Spridgets 8
B TR6 Oil pressure gauge-oil leaking behind the glass Triumph 2
K TR2/3/3A Oil pressure gauge readings? Triumph 9
M TR2/3/3A Oil pressure: the gauge? Triumph 4
Rut MGB Oil pressure gauge leather washer MG 13
Geo Hahn TR6 Oil Pressure Gauge Triumph 4
maxwedge5281 oil pressure gauge line...urgent!!! Austin Healey 10
K TR2/3/3A Oil pressure gauge indicator needle sticking? Triumph 10
PatGalvin TR2/3/3A Oil Pressure Gauge Leak - Leather Washer? Triumph 12
M TR2/3/3A Reading oil pressure gauge Triumph 3
K GT6 Spitfire oil pressure gauge readings? Triumph 4
pkmh Reinstalling oil pressure gauge in a BJ8 Austin Healey 4
P Mounting Bracket for Bugeye, Water/Oil Pressure Gauge Spridgets 5
NardisCNC Oil Pressure Gauge Questions..... Spridgets 8
JimTR4 Electric oil pressure gauge Triumph 20
Dougal BN1 Safety Gauge [oil pressure/water temp] number Austin Healey 4
T Oil Pressure Gauge braided line failure Austin Healey 6
S TR2/3/3A TR3A Oil Pressure Gauge Leather Gasket ?? Triumph 11
Stewart Removing the rectangular oil pressure gauge MG 5
sail Oil Pressure Gauge Stuck Triumph 4
60TR3A Leaky Oil Pressure Gauge Triumph 14
E Oil Pressure Gauge Pipe Fitting Spridgets 7
E Bugeye Oil Pressure Gauge Spridgets 5
tmc oil pressure gauge and line Triumph 5
The_architect oil pressure gauge lines: steel vs copper Spridgets 8
hondo402000 TR6 TR6 71 Oil pressure gauge Triumph 3
R Oil Pressure Gauge MG 3
W Oil pressure pipe - gauge to flex hose P/N 2A5640 Spridgets 10
RedTR3 TR2/3/3A TR3 Oil Pressure Gauge Hose Triumph 3
T 1500 oil pressure gauge leaking Spridgets 6
RickB Oil pressure gauge scared me last week... Spridgets 3
M Oil Gauge reading high pressure MG 3
RickB Dual temp / oil pressure gauge - how to remove? Spridgets 18
Atrus Oil Pressure fitting thread size [calibrate gauge] Spridgets 15
M Oil Pressure Gauge Triumph 0
