Oil pressure pipe - gauge to flex hose P/N 2A5640
Whitephrog
How long is this pipe? How does it route from the back of the gauge through the firewall?
Jim_Gruber
Ray, on Bugsy my '68 it is a solid copper pipe not a flex hose. Mine came disconnected and I found the logical easiest way to route.
Of course this was the same line that DPO forgot to connect when he started the engine and pumped about half a quart of 20W50 @ 70 psi sideways out of the engine. Oh and BTW, the access plate for the clutch bleeder is directly opposite the spot where you connect the oil pressure gauge. I spent 2-3 days simply cleaning up the PS footwells when Bugsy first came home just to get rid of all of the oil the DPO simply left laying in there for years.
Someone will post that diagram that shows what firewall holes are for what wires, fittings, hoses, etc,
W
Whitephrog
On the 1275cc engine the PO of my original (an dearly departed) Whitephrog had used a 4-ft steel braided line from the gauge directly to the block with a special fitting at the block (not the standard CAM6431 union. I don't want to use the braided line on the new Whitephrog. I believe that I have the three parts original to the car but I'm not certain.
jvandyke
Re: Oil pressure pipe - gauge to flex hose P/N 2A
On my '63 (different?) it's a metal line with a ferrel at the end, ends right about the solenoid where it tranitions to rubber then to block, not sure now what's at the block. Probably different on BE anyway.
Firewall holes
jlaird
Be has steel 1/8th line from the inst. throught the firewall. also a 2 inch peice on the block connected by a peice of braded hose.
Miss Agatha uses steel line the whole way.
HAN8L1965
If replacing the rubber line or braided line be sure and have the proper size line and the proper clamps, if they don't seal that line to the copper tubing correctly it makes a heck of a mess, and it will empty your oil in a hurry. Heck of a way to change your oil.
Mark
bugimike
One tip I would offer, when using the 1/8" copper line, be sure to put a couple of coils into the line to absorb vibration!
Jim_Gruber
Does this guy do beautiful work or what! Fabulous Ray. I just wish I had your skill. Hey what is your prediction on Vroom, Vroom sounds. We're all anxiously waiting for you and Drew.
bugimike
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
E Oil Pressure Gauge Pipe Fitting Spridgets 7
chicken Routing of oil pressure pipe through bulkhead Austin Healey 2
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
G High Oil Pressure Austin Healey 2
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
A MGB Oil pressure MG 9
K TR2/3/3A Oil pressure readings Triumph 10
J Oil Pressure Relief Valve Austin Healey 3
L Oil Pressure Gauge Austin Healey 5
LAW75 Oil Pressure Austin Healey 4
D TR2/3/3A oil pressure line venting? Triumph 4
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
R Bugeye oil pressure line Spridgets 9
K TR2/3/3A Oil pressure readings Triumph 3
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
S TR6 Oil Pressure Light Triumph 2
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
Kurtis No oil pressure Spridgets 5
V Braking Oil Pressure Austin Healey 16
N Suspected disaster - but it went well. Oil pressure restored. Austin Healey 1
S TR2/3/3A Oil pressure gauge removal Triumph 11
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Oil? Oil Pressure? Triumph 8
JFS TR6 No oil pressure Triumph 2
Simmo TR2/3/3A High Oil pressure Triumph 11
D TR5/TR250 High oil pressure Triumph 5
T TR6 Low Oil Pressure Light Triumph 3
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
K Time to build oil pressure Austin Healey 23
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
D BT7 oil pressure relief valve Austin Healey 19
D BT7 oil pressure relief valve Austin Healey 2
J Zero oil pressure at 4000 RPM Austin Healey 24
D TR2/3/3A oil pressure Triumph 6
HighAltitudeTR3 TR2/3/3A Oil Pressure low all of a sudden Triumph 10
S An oil volume question and an oil pressure question Austin Healey 5
L Wanted WANTED: good Working Oil Pressure GAUGE Triumph Classifieds 0
K TR2/3/3A Oil pressure gauge needle sticking? Triumph 4
K TR4/4A Oil pressure gauge Line? Triumph 5
B TR2/3/3A normal oil pressure in TR3 Triumph 6
Gliderman8 TR6 Stainless oil pressure line install HELP! Triumph 8
L 100 spin on oil filter part number, no oil pressure after replacement Austin Healey 8
G Need Help: Oil leak/crankcase pressure Spridgets 18
2billydavies TR2/3/3A very low oil pressure when TR3a is warmed up Triumph 12
