TR2/3/3A Reading oil pressure gauge
mallard
I got the new engine started today but will only run until the float bowls run out of fuel, which I have to fill manually . I may have a bad fuel pump. My question for now is how do you read the oil pressure gauge that is in kg/sq cm. The gauge has 4 numbers on it starting with 0 2 5 7. With the engine running I'm at the 3/4 mark or 5. According to Bill Piggott some cars came with this gauge. My car was originally dispatched to France so that may explain the different type gauge.
TR3driver
Great Pumpkin - R.I.P
1 kg/cm2 is about 14 psi. So 5 kg/cm2 is about 70 psi. Sounds perfectly normal to me.
M
mallard
Thanks Randall I thought the pressure was fine. With the needle at 3/4 I figured it had to be close to 70psi.
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
T Oil Pressure Gauge Not Reading Spridgets 8
M Oil Gauge reading high pressure MG 3
V TR6 TR6 Oil Pressure Reading Triumph 11
Basil Neat trick for reading oil level Restoration & Tools 7
Gliderman8 TR6 Excessive reading on volt gauge Triumph 17
Martinld123 Problems with my BN2 Temp Gauge reading Austin Healey 13
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
Joe Schlosser Spedo reading low Spridgets 8
K TR2/3/3A The Distributor Dwell reading... Triumph 1
roscoe Worth reading Austin Healey 3
sim fuel tank sender reading full all the time Spridgets 9
Tim Tucker TR4/4A Reading my TR4's plugs [L-87YC] Triumph 8
Healey Nut New Reading Austin Healey 3
T TR4/4A How hot at radiator neck when temp gauge is reading innthe middle Triumph 6
sundown TR6 1973 TR6 vacuum reading Triumph 2
pkmh Speed Reading vs. RPM Reading Austin Healey 7
Marvin Gruber Tachometer reading too high Jaguar 4
Perrymip The Pleasure of Reading Parts Catalogs Triumph 3
G 3.55 Avalible again? Am I reading this right? Spridgets 42
Nelson Vacuum reading access Spridgets 3
doates Fuel Gauge Reading Backwards Triumph 14
D Milleage counter incorrect reading MG 3
drooartz More tuneup, reading plugs Spridgets 0
TR6oldtimer Reading spark plugs as a tuning aid Triumph 19
JPSmit was reading an MG Mag tonight Spridgets 0
J Fuel Gauge Reading Austin Healey 1
K TR2/3/3A Tr3: Change in Diff=Change in Speedo reading? Triumph 7
M Fuel Gauge Not Reading Right Spridgets 10
J Vacume gauge reading on servo line Austin Healey 7
Steve1970 TR6 tr6 getting "0091" reading from VAG scanner Triumph 1
histerical Reading Material Spridgets 2
aeronca65t Reading, PA-Duryea Hillclimb Racing 1
T Wedge TR8 plug reading - my read is time for head job Triumph 26
RandallRK Temperature Gauge reading Austin Healey 2
B Recommended Rover Reading Rover / Land Rover 1
B Recommended Reading MG 5
Webb TR6 TR6; Amp Gauge Not Reading Positive Triumph 7
jlaird For some fun reading Spridgets 0
YankeeTR Good Reading....Gunner's Blog Triumph 0
YankeeTR Here's some good reading... Triumph 0
O TR6 TR6 Reading Triumph 3
Woodie reading schematic Spridgets 7
I TR6 TR6 gas gauge not reading correctly Triumph 11
G Great TR reading Triumph 0
D TR4/4A tr4 temperature gauge/sensor reading Triumph 11
jlaird A lot of good reading here, tips and how to Spridgets 1
T Torque reading Triumph 12
judow Great Reading Austin Healey 3
Morris Compression reading? Distrubutor timing? Spridgets 17
