TR2/3/3A Oil pressure: the gauge?
mmgwhite
Member
1959 TR3 with original oil pressure gauge.
Oil pressure starts out at about 70 psi but after driving for a while will drop into the 30s.
All else seems normal.
I dropped the oil pan and inspected the pickup screen. Seems fine.
Haven't sleuthed any further.
Suggestions how to proceed please
Thanks
TR3driver
Great Pumpkin - R.I.P
I assume you're talking about at idle. The owner's manual even mentions that low oil pressure may be shown when idling or running at low speeds, "this is quite normal". Typically a fresh engine won't show much drop if any, but as the bearings (and oil pump etc) wear, the drop becomes more pronounced. Using multiweight or heavier oil may help, but when it gets severe enough, it's time to replace the bearings and perhaps regrind the crank journals. The general rule of thumb for "enough" is 10 psi per 1000 rpm, so 30 psi at idle should be no problem at all.
It's fairly easy to change the rod bearings with the engine still in the car; in fact I believe it's the Haynes manual suggests doing it as a matter of periodic maintenance every 30,000 miles. That will usually pull the oil pressure back up quite a bit.
sp53
That all sounds Normal to me also, but I would get a second opinion before I went into major surgery. I have a collection of original gauges and one gauge I have shows correct oil pressure for about the first hour and then drops to zero at idle, and another one pretty much stays at 50 psi when cold, but drops down to 25 when the engine gets totally warm and comes back to 45psi when the idle increases . Anyways you can plumb in a new gauge for a while to double check the system. In addition there is a small gasket, I think made of leather to seal the old gauge, so if you do test out with a different gauge make sure you have one in place when you put the old gauge back because they can a big mess, I know.
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
L Oil Pressure Gauge Austin Healey 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
S TR2/3/3A Oil pressure gauge removal Triumph 11
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
L Wanted WANTED: good Working Oil Pressure GAUGE Triumph Classifieds 0
K TR2/3/3A Oil pressure gauge needle sticking? Triumph 4
K TR4/4A Oil pressure gauge Line? Triumph 5
6 General Tech Installing New Oil Pressure Gauge MG 5
6 Installing Oil Pressure Gauge Spridgets 2
Superwrench Oil Pressure/ Water temp Gauge Austin Healey 17
JimTR4 TR4/4A Oil pressure gauge hose Triumph 5
T Oil Pressure Gauge Not Reading Spridgets 8
B TR6 Oil pressure gauge-oil leaking behind the glass Triumph 2
K TR2/3/3A Oil pressure gauge readings? Triumph 9
Rut MGB Oil pressure gauge leather washer MG 13
Geo Hahn TR6 Oil Pressure Gauge Triumph 4
maxwedge5281 oil pressure gauge line...urgent!!! Austin Healey 10
K TR2/3/3A Oil pressure gauge indicator needle sticking? Triumph 10
PatGalvin TR2/3/3A Oil Pressure Gauge Leak - Leather Washer? Triumph 12
M TR2/3/3A Reading oil pressure gauge Triumph 3
K GT6 Spitfire oil pressure gauge readings? Triumph 4
pkmh Reinstalling oil pressure gauge in a BJ8 Austin Healey 4
P Mounting Bracket for Bugeye, Water/Oil Pressure Gauge Spridgets 5
NardisCNC Oil Pressure Gauge Questions..... Spridgets 8
JimTR4 Electric oil pressure gauge Triumph 20
Dougal BN1 Safety Gauge [oil pressure/water temp] number Austin Healey 4
T Oil Pressure Gauge braided line failure Austin Healey 6
S TR2/3/3A TR3A Oil Pressure Gauge Leather Gasket ?? Triumph 11
D Oil pressure gauge flex hose. Spridgets 29
Stewart Removing the rectangular oil pressure gauge MG 5
sail Oil Pressure Gauge Stuck Triumph 4
60TR3A Leaky Oil Pressure Gauge Triumph 14
E Oil Pressure Gauge Pipe Fitting Spridgets 7
E Bugeye Oil Pressure Gauge Spridgets 5
tmc oil pressure gauge and line Triumph 5
The_architect oil pressure gauge lines: steel vs copper Spridgets 8
hondo402000 TR6 TR6 71 Oil pressure gauge Triumph 3
R Oil Pressure Gauge MG 3
W Oil pressure pipe - gauge to flex hose P/N 2A5640 Spridgets 10
RedTR3 TR2/3/3A TR3 Oil Pressure Gauge Hose Triumph 3
T 1500 oil pressure gauge leaking Spridgets 6
RickB Oil pressure gauge scared me last week... Spridgets 3
M Oil Gauge reading high pressure MG 3
RickB Dual temp / oil pressure gauge - how to remove? Spridgets 18
Atrus Oil Pressure fitting thread size [calibrate gauge] Spridgets 15
M Oil Pressure Gauge Triumph 0
