Oil Pressure Gauge Questions.....
NardisCNC
My stock oil pressure gauge in my '66 midget has a splice/brass coupler in the line running from the engine to the gauge that has developed a small dripping leak and is making a mess.
Is there an alternative method of measuring pressure in a 1098/1275? Perhaps a pressure sensor that connects to the gauge electronically? Where would a person find such parts if so? What are quality brands to look for in gauges? I don't care about originality as much as I do form and function.
I am a novice so please excuse me if any of this sounds ignorant.
bug_sixty
first ingnorance is necessary to be on this site... sooo your in the club.... that aside your starting off with trying to reinvent the wheel... Just get the same item used.. It isn't something that goes sideways every few thousand miles.. There are other thing that have a tendency to do that... haha
All the cars had a "splice" to prevent vibrations from work hardening the copper line. If you repair it then it should be good for another 75,000 miles or 20 years.
NardisCNC
NardisCNC
Ok, great! Now, my car currently has a plastic oil pressure line.... should I repair it using a plastic / nylon line or is there any advantage / disadvantage to fitting a new copper line?
Oh, I misunderstood. I thought you had a the original copper line that someone installed a coupler rather that the rubber flex line.
In my sprite I have a black nylon tube that was supplied with my aftermarket gauges. It has a much thicker wall than the stuff supplied at the big box auto parts store.
dklawson
I have used nylon tubing for some cars but it is fragile, heat sensitive, hardens with age and is easily damaged when bumped. For a couple of dollars more you can buy the copper line kit which has obvious advantages compared to the nylon tube problems I just mentioned. However, to prevent fatigue damage you will need to wind a storage loop or two in the line between the engine and the firewall. I usually do this by wrapping the tubing around a small bottle then removing the bottle so there is a "spring" in the tubing.
The female fitting that comes in the gauge installation kits will fit the back of the Smiths mechanical oil pressure gauge but it is not made for it. The original factory fitting seals with a leather (or fiber) washer. The aftermarket kit uses 1/8 NPT fittings. They will seal if you put a wrap of Teflon tape on the gauge threads before installing the female tube fitting.
A more expensive but nice looking alternative is to get a metal braided oil pressure line kit from some place like Summit Racing. They sell kits from Longacre that are available in different lengths with longer hoses being more expensive. The braided hose kits are very nice looking and more robust than either the nylon or copper kits.
David_Doan
Doug,
I looked for the metal braided oil pressure line kits, but have not been able to find anything. Do you have a link?
dklawson
Summit does not make it easy to find the kits on their web site. Normal searches with logical keywords do NOT get you where you want to go. You practically have to know in advance what you want.
Try the following. Go to Summitracing.com and in the search field paste the following string: "Longacre Gauge Supply Line Kits"
That should result in a page with (4) different pre-fabricated gauge line kits in different lengths.
Their part numbers: LNG-45020, LNG-45030, LNG-45040, LNG-45050 (Prices from $20 to $32)
(The last non-zero number is the length of the line measured in feet).
A four-foot gauge line is also available from Mini Mani as their part
C-AHT9. However, they want $70 for their kit.
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
L Oil Pressure Gauge Austin Healey 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
S TR2/3/3A Oil pressure gauge removal Triumph 11
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
L Wanted WANTED: good Working Oil Pressure GAUGE Triumph Classifieds 0
K TR2/3/3A Oil pressure gauge needle sticking? Triumph 4
K TR4/4A Oil pressure gauge Line? Triumph 5
6 General Tech Installing New Oil Pressure Gauge MG 5
6 Installing Oil Pressure Gauge Spridgets 2
Superwrench Oil Pressure/ Water temp Gauge Austin Healey 17
JimTR4 TR4/4A Oil pressure gauge hose Triumph 5
T Oil Pressure Gauge Not Reading Spridgets 8
B TR6 Oil pressure gauge-oil leaking behind the glass Triumph 2
K TR2/3/3A Oil pressure gauge readings? Triumph 9
M TR2/3/3A Oil pressure: the gauge? Triumph 4
Rut MGB Oil pressure gauge leather washer MG 13
Geo Hahn TR6 Oil Pressure Gauge Triumph 4
maxwedge5281 oil pressure gauge line...urgent!!! Austin Healey 10
K TR2/3/3A Oil pressure gauge indicator needle sticking? Triumph 10
PatGalvin TR2/3/3A Oil Pressure Gauge Leak - Leather Washer? Triumph 12
M TR2/3/3A Reading oil pressure gauge Triumph 3
K GT6 Spitfire oil pressure gauge readings? Triumph 4
pkmh Reinstalling oil pressure gauge in a BJ8 Austin Healey 4
P Mounting Bracket for Bugeye, Water/Oil Pressure Gauge Spridgets 5
JimTR4 Electric oil pressure gauge Triumph 20
Dougal BN1 Safety Gauge [oil pressure/water temp] number Austin Healey 4
T Oil Pressure Gauge braided line failure Austin Healey 6
S TR2/3/3A TR3A Oil Pressure Gauge Leather Gasket ?? Triumph 11
D Oil pressure gauge flex hose. Spridgets 29
Stewart Removing the rectangular oil pressure gauge MG 5
sail Oil Pressure Gauge Stuck Triumph 4
60TR3A Leaky Oil Pressure Gauge Triumph 14
E Oil Pressure Gauge Pipe Fitting Spridgets 7
E Bugeye Oil Pressure Gauge Spridgets 5
tmc oil pressure gauge and line Triumph 5
The_architect oil pressure gauge lines: steel vs copper Spridgets 8
hondo402000 TR6 TR6 71 Oil pressure gauge Triumph 3
R Oil Pressure Gauge MG 3
W Oil pressure pipe - gauge to flex hose P/N 2A5640 Spridgets 10
RedTR3 TR2/3/3A TR3 Oil Pressure Gauge Hose Triumph 3
T 1500 oil pressure gauge leaking Spridgets 6
RickB Oil pressure gauge scared me last week... Spridgets 3
M Oil Gauge reading high pressure MG 3
RickB Dual temp / oil pressure gauge - how to remove? Spridgets 18
Atrus Oil Pressure fitting thread size [calibrate gauge] Spridgets 15
M Oil Pressure Gauge Triumph 0
