TR2/3/3A TR3A Oil Pressure Gauge Leather Gasket ??
SPACER
Member
When I removed my TR3A oil pressure gauge, I noticed there was no leather or rubber gasket on the pressure line where it attaches to the gauge.
So I assembled it without one.
Then read other non TR3 posts where a leather gasket is used.
Should there be one on the TR3A and if so, what does it look like?
I have not seen any on the usual supplier catalogs so perhaps I can cut one if needed.
Thanks,
Bob
ShawnC_at_Moss
Bob,
We carry it. It is a 435-515 but I don't see it on our TR2-4A website but it is in our current catalog - Page 94 item 18a. I have attached an image. If you need one send me an email at shawn@mossmotors.com
TR3driver
Great Pumpkin - R.I.P
Should be there, IMO, otherwise the joint will tend to drip oil while you're driving. It's easily overlooked though. Don't recall the size offhand, but I found a nylon flat washer that fit, and worked well for me.
6TTR3A
<span style="font-size: 11pt"><span style="color: #003300">I found a neoprene o-ring that fits perfectly at our specialty hardware store. 5 yr. with no problems for me.
Frank </span></span>
CJD
Interesting! So, are there supposed to be gaskets at both ends of the flex tube under the bonnet?
John
hondo402000
I would replace that line with a braided SS one, I never liked that plastic tubing, was always afraid it would split and all the oil would get pumped out and then major engine damage
but thats just my opinion
Hondo
TFB
Awhile back after becoming aware of this part from reading this forum,I looked at the mating surfaces and you can clearly see the seat faces have a gap for the washer.
I just made one from good gasket paper.Punched,I believe,a 1/4 hole,then a 3/8 hole around it.If you punch the small hole last it tears.
Tom
TR3driver
Huh? What plastic tubing? Original TR3A had no plastic in the oil pressure line. And while the braiding on the stock line was only copper, it still lasts basically forever.
dklawson
Plastic tubing isn't inherently bad such that it would burst. However, it does become brittle with age and of course you have to worry about running it next to heat or bumping it accidentally where it goes into the fitting.
I managed to destroy a plastic gauge tube on the Mini while working on the engine and have since replaced it with a copper line kit. On the Spitfire the oil pressure gauge was not stock but I added one. For it I bought a braided oil line kit from Summit. With any of the generic kits (nylon, copper, or braided hose) the fittings will be different than what you find on the Smiths gauge. However, I have always found that a wrap of Teflon tape on the gauge's male threads allows the 1/8NPT female fittings in the kit to seal nicely.
None of this addresses the original fittings and the leather/fiber washer. Like Randall, I would fit one whether it is homemade from gasket paper, a nylon washer, or purchased from Moss.
2billydavies TR2/3/3A very low oil pressure when TR3a is warmed up Triumph 12
mgbmedic TR2/3/3A oil pressure line routing TR3A Triumph 4
rlandrum TR2/3/3A TR3A Low Oil Pressure Solved Triumph 19
NutmegCT TR2/3/3A oil pressure TR3A Triumph 5
A TR2/3/3A A rigged TR3a oil filter housing Triumph 8
C TR2/3/3A Oil Catch Can TR3a Triumph 8
D TR2/3/3A '59 TR3A oil pan leak Triumph 12
M_Pied_Lourd TR2/3/3A 59 TR3A Front Hub Oil Seal Triumph 2
A TR2/3/3A Tr3A Oil Priming Triumph 11
Tinkerman TR2/3/3A Major oil leak from original oil filter system 1960 TR3A post 600000 series Triumph 3
B TR2/3/3A TR3a oil line at block question Triumph 5
V TR2/3/3A TR3A Front Oil Seal Triumph 3
H TR2/3/3A Oil Sump Thread size TR3A Triumph 4
H TR2/3/3A TR3A Oil Leak Triumph 4
M_Pied_Lourd TR2/3/3A TR3A Oil Cooler Opinions Triumph 5
MGTF1250Dave TR2/3/3A TR3A Rear Axle Pinion Oil Seal Replacement Triumph 8
ekamm TR2/3/3A tr3a transmission oil preferences? Triumph 4
T TR2/3/3A 1960 TR3A oil leak issue [imagine that!] Triumph 5
H TR2/3/3A TR3A Oil sump drain plug [Thread zize] Triumph 2
rlandrum TR2/3/3A TR3A Timing Chain Oil Slinger Triumph 3
B TR2/3/3A TR3A Oil Gallery plug Triumph 6
NutmegCT TR2/3/3A original oil filter, TR3A Triumph 6
jdubois TR2/3/3A Should be oil in a TR3A steering rack, right? Triumph 16
TRclassic3 TR2/3/3A TR3A steering box oil Triumph 10
NutmegCT TR2/3/3A TR3A oil gauge stuck Triumph 11
J TR2/3/3A Oil change on TR3A Triumph 5
S TR2/3/3A TR3A oil by-pass to cylinder head Triumph 11
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
