TR2/3/3A TR3A Oil sump drain plug [Thread zize]
martx-5
It's a pipe plug. I just crawled under my TR3, and it looks to be a 3/8" fitting which would make it 3/8"-18 NPT. Might be 1/4"-18, but it looks bigger then that.
Don Elliott
Definitely a very standard pipe thread. Get one at any plumbing supply shop. Or come by and I'll give you one. I have several, since I bought and installed some magnetic plugs last year.
H TR2/3/3A Oil Sump Thread size TR3A Triumph 4
A TR2/3/3A A rigged TR3a oil filter housing Triumph 8
C TR2/3/3A Oil Catch Can TR3a Triumph 8
2billydavies TR2/3/3A very low oil pressure when TR3a is warmed up Triumph 12
D TR2/3/3A '59 TR3A oil pan leak Triumph 12
M_Pied_Lourd TR2/3/3A 59 TR3A Front Hub Oil Seal Triumph 2
A TR2/3/3A Tr3A Oil Priming Triumph 11
Tinkerman TR2/3/3A Major oil leak from original oil filter system 1960 TR3A post 600000 series Triumph 3
B TR2/3/3A TR3a oil line at block question Triumph 5
mgbmedic TR2/3/3A oil pressure line routing TR3A Triumph 4
S TR2/3/3A TR3A Oil Pressure Gauge Leather Gasket ?? Triumph 11
V TR2/3/3A TR3A Front Oil Seal Triumph 3
H TR2/3/3A TR3A Oil Leak Triumph 4
M_Pied_Lourd TR2/3/3A TR3A Oil Cooler Opinions Triumph 5
MGTF1250Dave TR2/3/3A TR3A Rear Axle Pinion Oil Seal Replacement Triumph 8
ekamm TR2/3/3A tr3a transmission oil preferences? Triumph 4
rlandrum TR2/3/3A TR3A Low Oil Pressure Solved Triumph 19
T TR2/3/3A 1960 TR3A oil leak issue [imagine that!] Triumph 5
rlandrum TR2/3/3A TR3A Timing Chain Oil Slinger Triumph 3
B TR2/3/3A TR3A Oil Gallery plug Triumph 6
NutmegCT TR2/3/3A oil pressure TR3A Triumph 5
NutmegCT TR2/3/3A original oil filter, TR3A Triumph 6
jdubois TR2/3/3A Should be oil in a TR3A steering rack, right? Triumph 16
TRclassic3 TR2/3/3A TR3A steering box oil Triumph 10
NutmegCT TR2/3/3A TR3A oil gauge stuck Triumph 11
J TR2/3/3A Oil change on TR3A Triumph 5
S TR2/3/3A TR3A oil by-pass to cylinder head Triumph 11
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
