GM evidently makes a good steering box lube. I am trying to track some down. It is supposed to be "thick" enough to resist leaking. Otherwise, I get steering box lube from a Model A supplier (Brattons in Maryland) It is made to replace the 600wt that ford specified, and has worked for years in various cars (TR3s, and XK120s) with no ill effects. Other folks probably use other things, your results may be different, etc.....
