Dan_Pasta
Member
I'm refreshing the steering on my 59 TR3. The silentbloc bushing on the driver side is completly shot .... the one on the passenger side is not far behind.
Since the bushings will need to be pressed in I've decided to remove the whole steering assembly (tie rods idler arms etc.) as a unit and check everything while I was at it. My problem is in removing the Drop arm nut (the one that bolts onto the rocker shaft below the drop arm). There doesn't seem to be enough clearance to get a socket or wrench in there ... Do I need to further disassemble frame/suspension to get at it ..... do I need a special tool of some sort ... bigger hammer .... cutting torch ..... dynamite .... more beer ..... well the beer is a given, but any tricks out there????
Thanks in advance
Dan
Thanks in advance
Dan
