Hi, I am getting ready to replace the oil seal in the steering box and the books say to remove the box from the car. It looks like I have a one piece steering column. It is solid from the box to the wheel. Can someone confirm that I do need to pull the steering wheel and the entire steering column to get the box out far enough to pull the pitman arm and replace the seals?
By the way, I have rebuilt both front brake calipers and installed the new silentbloc bushings. Thanks for all the good advice about replacing those parts. The steering box is the last item to fix before heading back to the garage for an inspection.
