61TR3A said:
Is there any other way to speed up steering from 3.5 turns lock-to-lock to 2.5 and make sawing the wheel a little less muscular?
Do a proper rebuild on the stock steering box. When I finally broke down and did mine, I was amazed at the result; and the process wasn't nearly as hard as I had envisioned.
BTW, the stock setup is 2.25 turns lock-to-lock, which is part of the reason it's kind of stiff. My TR3 didn't turn out as well the first time as the 3A did (probably because I felt the box was good enough and didn't replace the bushing & seal), but I can still park with one hand.
Although part of the trick is that I learned to drive on a full size car with manual steering. One of the lessons learned is to not try to turn the wheel with the car absolutely still. Letting it roll just a few inches will make it much easier to turn the wheel.
And as noted, running more air in the tires will help, too. Also seems to improve handling, so it's win-win.
PS, Synthetic GL5 gear oil seems to work better in the steering box.
