TR2/3/3A TR3A steering column
griff
I just received my 2 rubber/nylon bush3s Moss part number 525-020 for the split-column and cannot figure out how to install them properly. On disaseembly, I found only a make shift washer used to keep the inner rod centered.
Can someone share with me exactly where they go and how to get the bush over the larger portion near the top of the column?
Also upon correct installation is the bush entirely inside the outer column or does a portion hang out?
Thanks,
Griff
Tinkerman
So far Griff, mine have been intirely inside the column. The rubber bushes have two rubber bumps and those correspond to the two holes on the side of the steering column. I used Lithium grease and squished the bumps down until they slid into place. I have a two pc. column so I have another one to do as soon as the upper column is painted. There is also an anti rattle washer and a felt bush that goes into the assembly. You can see those in the Moss diagram.
Good Luck, Tinkerman
G
griff
Dick,
Help me out here. According to the Moss catalog the split column uses two rubber/nylon bushes and the felt bush. It specifies the anti-rattle ring is for the rigid column.
Also, the tip on the lithium grease sounds good, But, my biggest problem is how to get the rod inserted through the bushes.
It appears they are rubber with a nylon/plastic sleeve on the inside and I do not see the sleeve stretching enough to go over the large portion of the steering rod even if I grease them up. Am I missing something that should be entirely obvious?
Thanks,
Griff
TR3driver
Great Pumpkin - R.I.P
There is also steel in that sandwich (at least on the originals), so no way are they going to stretch over anything. But they should not need to.
The sleeves go just inside the end of the tubes, on either side of the 'split', so the bottom section of steering shaft gets pushed up from the bottom (through the steering box), and the top section gets pushed down from the top (through the felt bush). The large portion of the shaft stays at the top (in the felt bush). The splines that go into the coupling are the same size as the shaft where the rubber/nylon things ride, so they should slip right in.
Hmm, just for clarity, the rubber/nylon things should be installed first (preferably with the column still out of the car). As Dick says, a little grease will help the rubber slide into the tubes, and there should be two holes in each tube for the 'ears' to stick out of. A little grease inside is a good idea too, IMO, but they don't fit all that tight on the shaft so the grease inside is more to prevent rust than needed for easy installation.
Tinkerman
Griff. I'll let you know later today, had to order another bushing so will take a look at it. Small shipment of related parts due in today or tomorrow. Just went looking for the old one I took out yesterday but could'nt find it. I suspect it will slide on over the bottom end of the shaft. That is to say you will have to install the bush then slide the steering shaft in from the top end of the steering column. Your probably right about the anti rattle ring, but I bought one so I'm going to use it.
Was your stator tube clean? If not how did you clean it?
I just reread your post. One of the bushs goes in the steering box column and the other goes in the bottom of the steering wheel part of the column. So I suspect that you get that assembled outside of the car slide in the steering rod and then install them as a unit. I'm going to post this and then go look at a couple of pictures. If anything changes I'll re-post
Dick
G
griff
Thank you to both Randall and Dick. I understand now. I had installed the lower shaft several weeks ago and am now prepping the upper. When I looked at the Moss catalog pic, it appeared they were referencing the bush as item 9 and showing it at the top of the column as well.
So D/A me, I ordered two bushes for the upper section and only needed one and the felt bush.
Thanks again,
Donnie "Griff"
TR3driver
Mine was cruddy inside, so I alternated spraying with Gumout and forcing bearing balls through it until it seemed cleaner. Also discovered this time that the lubricant they sell at Home Depot for pulling wires through conduit makes pulling wires through that tube a whole lot easier. Messy, but effective. And it cleaned up pretty easy.
Tinkerman
Whoa! What a great tip. I've some heard real horror stories about pulling the wires through and what a toughy it was. Wire pulling lubricant, guess it's off to Lowes tomorrow, No HD here, drat. By the way did you pull the wires before or after installing the stator tube?
I like the grease idea for the steering shaft also, guess that will go on the list.
Tinkerman
TR3driver
I think this is the stuff I got: https://www.ecoupons.com/products/home-depot/1731886/MTAwNjQ3NzQ2 Don't know that it's any better or worse than anything else; but it seemed to help a lot. I had pulled the original harness in two trying to get it through, then the replacement harness from TRF seemed likely to break, before I started over with the lubricant. With the lube, it just slid right in.
Definitely done out of the car. After fishing a length of baling (solid steel approx 20 AWG) wire through the tube, I crimped it around the harness between the end of the jacket and the bullets, then wrapped a single layer of tape over the pulling wire, bullets and end of the jacket. Clamped the other end of the baling wire in the bench vise and started pulling on the tube, lubricating and guiding the harness into the end.
I stopped when the wires were protruding only a few inches from the tube, undid the tape & baling wire, and installed the tube in the car. From that point it was easy to pull the harness the rest of the way through the tube.
PS, be sure you have the tube turned the right way. The bullets should come out of the end without the slot.
Not that I've ever done anything like that backwards.
G
griff
Dick,
I haven't dug the stator tube out of storage yet, but as I recall it was fairly decent with just a little crud near the bottom end. I will probably clean it though as I have a new control head to install.
For stuff like that I usually use GUNK engine degreaser and CRC (both are great cleaners) But, I do like the idea of rolling some loose balls from bearings through to knock everything loose.
Although sitting here thinking about it couldn't one just shoot some fine sand through end to end?
Later
Griff
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
T TR2/3/3A How to identify what steering box and column I have on a TR3a? Triumph 12
Brinkerhoff TR2/3/3A TR3A steering column grommet - picture? Triumph 2
Tinkerman TR2/3/3A TR3A Steering Column Clamp Triumph 7
angelfj1 TR2/3/3A TR3A steering column [two-piece] coupling Triumph 2
S TR2/3/3A TR3A steering column- one piece column removal? Triumph 4
J TR2/3/3A TR3A Adjustable Steering Triumph 5
B TR2/3/3A TR3a steering box rebuild Triumph 19
T For Sale - 1961 TR3A Steering Box Triumph Classifieds 8
K For Sale TR3A Steering wheel Triumph Classifieds 4
T TR2/3/3A Questions on TR3A steering control head refresh Triumph 34
P TR2/3/3A TR3A Steering Control Head Harness Triumph 7
K TR2/3/3A DIY TR3A Rack and Pinion Steering Conversion Triumph 0
Lbp TR2/3/3A TR3A - Converting Adjustable Steering Wheel to Standard? Triumph 16
BJ8Healeys TR2/3/3A TR3A Steering Gearbox Triumph 27
T TR2/3/3A Is this normal wiring on front of steering box on TR3A? Triumph 12
Lukens TR2/3/3A Aligning steering wheel on TR3A Triumph 3
Simmo TR2/3/3A Mota Lita Steering wheel on TR3A. Help! Please. Triumph 4
PatGalvin TR2/3/3A Steering Wheel Diameter with R&P Steering, TR3A Triumph 9
Bremer TR2/3/3A Steering box rebuild TR3A Triumph 8
T TR2/3/3A TR3A tight steering/silent blocks Triumph 8
60TR3A TR2/3/3A TR3A Conversion to Rack-&-Pinion Steering Triumph 33
N TR2/3/3A steering box for TR3A Triumph 14
G TR2/3/3A How does TR3A Adjustable Steering Work? Triumph 5
N TR2/3/3A TR3A steering box Triumph 2
CraigLandrum TR2/3/3A TR3A Steering Shaft stator tube??? Triumph 26
angelfj1 TR2/3/3A TR3A Steering Worm - Can this be Restored? Triumph 15
M TR2/3/3A TR3A steering wheel splines Triumph 1
rlandrum TR2/3/3A TR3A Steering Bearing and Race Triumph 3
T TR2/3/3A Leaky Steering Box [TR3A] Triumph 29
Got_All_4 TR2/3/3A Removal of Steering Box Worm Gear In Car TR3A Triumph 3
MGTF1250Dave TR2/3/3A TR3A Steering Wheels and Columns Triumph 13
C TR2/3/3A I want to change my Tr3A steering wheel... Triumph 6
jdubois TR2/3/3A Should be oil in a TR3A steering rack, right? Triumph 16
N TR2/3/3A TR3A Steering Adjustment Triumph 6
TRclassic3 TR2/3/3A TR3A steering box oil Triumph 10
F TR2/3/3A TR3A Steering Wheel Cover Triumph 1
Dan_Pasta TR2/3/3A TR3A steering rebuild help Triumph 10
Dan_Pasta TR2/3/3A TR3A steering slop Triumph 0
S TR2/3/3A TR3A steering wheel Triumph 32
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
