TR2/3/3A TR3A steering slop
Dan_Pasta
Member
The idler bracket/lever has wayyyyyyy to much "play" and needs to be replaced. At first blush it doesn't look like I'll be able to remove the old sloppy bracket without first removing the tie rod .... however .... the manual seems to indicate I can. Does anybody have any experiance replaceing the idler bracket???? Any hints before I start to disassemble my steering system???? Thanks in advance for your help.
J TR2/3/3A TR3A Adjustable Steering Triumph 5
B TR2/3/3A TR3a steering box rebuild Triumph 19
T For Sale - 1961 TR3A Steering Box Triumph Classifieds 8
K For Sale TR3A Steering wheel Triumph Classifieds 4
T TR2/3/3A Questions on TR3A steering control head refresh Triumph 34
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
P TR2/3/3A TR3A Steering Control Head Harness Triumph 7
K TR2/3/3A DIY TR3A Rack and Pinion Steering Conversion Triumph 0
T TR2/3/3A How to identify what steering box and column I have on a TR3a? Triumph 12
Brinkerhoff TR2/3/3A TR3A steering column grommet - picture? Triumph 2
Lbp TR2/3/3A TR3A - Converting Adjustable Steering Wheel to Standard? Triumph 16
BJ8Healeys TR2/3/3A TR3A Steering Gearbox Triumph 27
T TR2/3/3A Is this normal wiring on front of steering box on TR3A? Triumph 12
Lukens TR2/3/3A Aligning steering wheel on TR3A Triumph 3
Simmo TR2/3/3A Mota Lita Steering wheel on TR3A. Help! Please. Triumph 4
PatGalvin TR2/3/3A Steering Wheel Diameter with R&P Steering, TR3A Triumph 9
Bremer TR2/3/3A Steering box rebuild TR3A Triumph 8
T TR2/3/3A TR3A tight steering/silent blocks Triumph 8
60TR3A TR2/3/3A TR3A Conversion to Rack-&-Pinion Steering Triumph 33
N TR2/3/3A steering box for TR3A Triumph 14
G TR2/3/3A How does TR3A Adjustable Steering Work? Triumph 5
N TR2/3/3A TR3A steering box Triumph 2
G TR2/3/3A TR3A steering column Triumph 10
Tinkerman TR2/3/3A TR3A Steering Column Clamp Triumph 7
CraigLandrum TR2/3/3A TR3A Steering Shaft stator tube??? Triumph 26
angelfj1 TR2/3/3A TR3A Steering Worm - Can this be Restored? Triumph 15
M TR2/3/3A TR3A steering wheel splines Triumph 1
rlandrum TR2/3/3A TR3A Steering Bearing and Race Triumph 3
angelfj1 TR2/3/3A TR3A steering column [two-piece] coupling Triumph 2
T TR2/3/3A Leaky Steering Box [TR3A] Triumph 29
Got_All_4 TR2/3/3A Removal of Steering Box Worm Gear In Car TR3A Triumph 3
MGTF1250Dave TR2/3/3A TR3A Steering Wheels and Columns Triumph 13
C TR2/3/3A I want to change my Tr3A steering wheel... Triumph 6
jdubois TR2/3/3A Should be oil in a TR3A steering rack, right? Triumph 16
N TR2/3/3A TR3A Steering Adjustment Triumph 6
TRclassic3 TR2/3/3A TR3A steering box oil Triumph 10
F TR2/3/3A TR3A Steering Wheel Cover Triumph 1
Dan_Pasta TR2/3/3A TR3A steering rebuild help Triumph 10
S TR2/3/3A TR3A steering wheel Triumph 32
S TR2/3/3A TR3A steering column- one piece column removal? Triumph 4
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
