TR2/3/3A TR3A Steering Control Head Harness
PaulLongBl
Member
Anyone here ever build a replacement control head harness? Tips? If so how easy was it to do, what wire sizes did you use, and did wrap it and if so with what?
Thanks
TR3driver
Great Pumpkin - R.I.P
I just bought one instead, they're readily available from the usual suspects.
One problem I see is that the tiny ring terminals that go inside the control head are "specials", they have a locating tab that sticks into a hole in the Bakelite to keep the terminal from turning and perhaps shorting out.
TR3driver
I've searched two of the suppliers and haven't found the item. Did you have to ask for it specifically?
No, I just ordered it the way I always do: Look up the factory part number in the factory parts book, then order that number from TRF. Web site says it's still available: UNTITLED.jpg
Moss shows in stock, too.
https://mossmotors.com/harness-included-with-control-heads
If you don't have a factory parts manual, I suggest you get one. TRF will sell you a paper copy, or you can download a PDF from
https://drive.google.com/open?id=0B2H2NJt34OffMWQ4N2EzZGQtNjc0Ny00YmE2LWFiN2UtZWYzMjNjNGFiYzY4
(I just added some bookmarks, circles and arrows ... to be used as evidence against us.)
bobhustead
I recall that the new harness that came with my new head had an orderly twist in the wires to facilitate twisting the harness down the tube.
Bob
CJD
Yeah, the wire size is critical, as is the thickness of the wrapping. This is just one of those parts I wouldn't personally consider doing myself unless it wasn't available otherwise. Moss shows it for $38...which is higher than it used to be. I found mine on ebay for $22 and it's cloth wrapped. I could not build for that price.
T TR2/3/3A Questions on TR3A steering control head refresh Triumph 34
J TR2/3/3A TR3A Adjustable Steering Triumph 5
B TR2/3/3A TR3a steering box rebuild Triumph 19
T For Sale - 1961 TR3A Steering Box Triumph Classifieds 8
K For Sale TR3A Steering wheel Triumph Classifieds 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
K TR2/3/3A DIY TR3A Rack and Pinion Steering Conversion Triumph 0
T TR2/3/3A How to identify what steering box and column I have on a TR3a? Triumph 12
Brinkerhoff TR2/3/3A TR3A steering column grommet - picture? Triumph 2
Lbp TR2/3/3A TR3A - Converting Adjustable Steering Wheel to Standard? Triumph 16
BJ8Healeys TR2/3/3A TR3A Steering Gearbox Triumph 27
T TR2/3/3A Is this normal wiring on front of steering box on TR3A? Triumph 12
Lukens TR2/3/3A Aligning steering wheel on TR3A Triumph 3
Simmo TR2/3/3A Mota Lita Steering wheel on TR3A. Help! Please. Triumph 4
PatGalvin TR2/3/3A Steering Wheel Diameter with R&P Steering, TR3A Triumph 9
Bremer TR2/3/3A Steering box rebuild TR3A Triumph 8
T TR2/3/3A TR3A tight steering/silent blocks Triumph 8
60TR3A TR2/3/3A TR3A Conversion to Rack-&-Pinion Steering Triumph 33
N TR2/3/3A steering box for TR3A Triumph 14
G TR2/3/3A How does TR3A Adjustable Steering Work? Triumph 5
N TR2/3/3A TR3A steering box Triumph 2
G TR2/3/3A TR3A steering column Triumph 10
Tinkerman TR2/3/3A TR3A Steering Column Clamp Triumph 7
CraigLandrum TR2/3/3A TR3A Steering Shaft stator tube??? Triumph 26
angelfj1 TR2/3/3A TR3A Steering Worm - Can this be Restored? Triumph 15
M TR2/3/3A TR3A steering wheel splines Triumph 1
rlandrum TR2/3/3A TR3A Steering Bearing and Race Triumph 3
angelfj1 TR2/3/3A TR3A steering column [two-piece] coupling Triumph 2
T TR2/3/3A Leaky Steering Box [TR3A] Triumph 29
Got_All_4 TR2/3/3A Removal of Steering Box Worm Gear In Car TR3A Triumph 3
MGTF1250Dave TR2/3/3A TR3A Steering Wheels and Columns Triumph 13
C TR2/3/3A I want to change my Tr3A steering wheel... Triumph 6
jdubois TR2/3/3A Should be oil in a TR3A steering rack, right? Triumph 16
N TR2/3/3A TR3A Steering Adjustment Triumph 6
TRclassic3 TR2/3/3A TR3A steering box oil Triumph 10
F TR2/3/3A TR3A Steering Wheel Cover Triumph 1
Dan_Pasta TR2/3/3A TR3A steering rebuild help Triumph 10
Dan_Pasta TR2/3/3A TR3A steering slop Triumph 0
S TR2/3/3A TR3A steering wheel Triumph 32
S TR2/3/3A TR3A steering column- one piece column removal? Triumph 4
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
