GT6 Spitfire oil pressure gauge readings?
karls59tr
Bronze
What kind of oil pressure reading should the gauge show after a hard run? What is considered too low a reading...one that would indicate a serious problem? Same question for the GT6.
dklawson
Well... there are the technical answers and the feel good answers.
As you have seen, after a hard run the pressure will be lower. The grade of oil you use and engine temperature all affect this as does your idle speed. I believe the hotrod guys (not Triumph guys... just regular gearheads) used to say minimum 10 PSI at idle and 10 PSI for each 1000 RPM up from there until your relief valve opens. The Spitfire/GT6 oil pressure warning switch doesn't come on until about 5 PSI so if you see it... you really have problems. Personally, I would like to see 30 PSI at idle but on hot summer days I am sure our car will hover closer to 25 PSI with a 1000 RPM idle and 20W50 oil. You can improve that by having an efficient cooling system and perhaps adding electric fans.
I am sure others will have their own preferences and observations on normal oil pressure. I have never seen any factory limits for these engines. Hopefully someone will post those numbers if such values exist.
3798j
Bronze
This from the Haynes Triumph GT6 & Vitesse workshop manual:
Note: Low oil pressure in a high-mileage engine at tickover is not necessarily a cause for concern.
Normal oil pressure at 2000 rpm.........40 to 60 lbs.
number6
One thing I've found is that individual gauges are not all that consistent. I installed new smiths gauge in my 79 Spitfire and on start up pressure is in the 80's. Thinking that was very high, swapped it for an older gauge I had and on start up
never got above 60. After a hard run low side was 20 and 30 respectively
Number 6
79 spit, 67 rover 2000tc 69 mgc sunbeam harrington 04 jag x type
dklawson Spitfire '72 Spitfire Oil Pressure Up-date Triumph 5
dklawson Spitfire Spitfire - Gearbox & Oil Pressure? Triumph 17
78Z Spitfire Oil pressure in a 1500 Spitfire Triumph 9
JBann Spitfire Oil Filter for Mk1 Spitfire Triumph 7
dklawson Spitfire Crank Endfloat and Oil Pumps - Spitfire 1500 Triumph 9
Darwin Spitfire Spitfire oil slinger Triumph 2
roofman Spitfire Spitfire oil pan gasket question. Triumph 8
dklawson Spitfire Spitfire - Oil Filter Choices Triumph 8
R Spitfire spitfire transmission and j type O/D oil question Triumph 29
cutlass29 Spitfire spitfire mk3 rear engine oil seal Triumph 1
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
S Spitfire Spitfire 1296 engines Triumph 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Spitfire Spitfire 1500 Triumph 3
T Spitfire Spitfire lights Triumph 7
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
