MGB Awakening my 1978 MGB - No Results
Having driven the 1969 MGC to shows, rallyes, etc, since 1999...I put the 1978 MGB into storage at that time...Kind of forgot about her.
Last night I looked at her...and decided to wake her up.
Put in a new battery...pulled the coil wire...shot some oil into the cylinders...spun the starter.
Fuel pump worked immediately...oil pressure gained almost immediately.
This car has a points distributor, NOT an electronic ignition.
Put the coil wire back on and spun her over again....no fire.
Gave her a shot of starting fluid....no fire.
Pulled the coil wire from the distributor and held it near the block, spun the starter...no spark.
Checked coil for voltage...almost 13v on the ignition side.
Checked the black/white leads to the distributor for resistance...wires good.
Pulled the distributor cap and spun the engine (with the coil wire reattached) - no spark.
Put in a new coil...no difference.
Checked the points for resistance...no resistance when they are open OR closed...so the problem appears to lie within the distributor.
There is voltage from the coil to the distributor.
There is no spark when the points open.
So...I'm taking the MGC to the Champagne British Car Festival tomorrow....
Tomorrow upon my return home, I'll change the points and see if that remedies anything...but if it does NOT...where should I look? Can a condensor go bad just sitting in storage?
PAUL161
Rick, did you see if the points have a film over them? Don't know why they get that film on them when their not used over a period of time, but they do. I've used a drop of brake clean, of all things, on a stiff piece of paper to clean the film off and it worked without compromising the points surface. Worth a try if you haven't already done so. PJ
rick_ingram
No...I did not check that...and will do so when I return from Bloomington this afternoon!
It has to be something simple.
The car was running when I stored it.
But, how often have we heard THAT line?!
:wink:
Like Paul said, points probably need cleaning or changing out. A quick test is, pull the distr cap off, turn the ignition on, use a flat tip screwdriver and push it between the points, you may need to rock it some,but you should see fire. That will be a good indication of points corroded.
Marv
Platinum
Yup. Run some #400 wet-or-dry thru the points 'til they're shiny. It'll fire right up.
Basil General Tech Awakening a Sleeping MGB MG 5
ckeithjordan TR2/3/3A Awakening a Slumbering TR Triumph 16
WillR MGB Awakening grumbles. MG 21
apbos Awakening the Smooth Case Transmission Spridgets 7
MCNX_BFF Awakening the Beastie...trying to! Triumph 41
dklawson Re-awakening an Engine - Not Quite the Usual ? Triumph 5
G Girls Awakening Austin Healey 2
macino62 awakening.... Triumph 5
vping Awakening a sleeping B MG 7
Darwin Need help awakening a B MG 2
tony barnhill Awakening a Sleeping MG MG 3
M For Sale 1978 MGB MG Classifieds 0
M 1978 London Taxi Passengers Other British Cars 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
G MGB 1978 MGB clutch is out..! MG 39
R For Sale Time Capsule 1978 MGB MG Classifieds 1
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
S MGB 1978, replacing the clutch. MG 3
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
M MGB 1978 mg fuel smell MG 23
M Hello again. I have a 1978 Triumph spitfire. Triumph 17
Kleykamp For Sale 1978 MG Midget Best Offer Spridgets Classified 0
Kleykamp For Sale 1978 MG Midget photos added Spridgets Classified 0
Kleykamp For Sale 1978 MG Midget project or parts Spridgets Classified 0
S MGB Newbie 1978 MGB questions MG 11
M Spitfire need a crankshaft pulley for 1978 Spitfire Triumph 0
TomR 1978 MG Midget with Points Distributor Spridgets 4
B MGB anyone have a photo of a 1978 MGB dashboard to left of steering and console ? MG 9
B MGB 1978 MGB 2 wires hanging under the dash to the .. MG 4
rovernut 1978 with black seats..biscuit interior..Original? MG 2
L 1978 mg midget seat belt replacement Spridgets 3
rick_ingram MGB Wheel Upgrade - 1978 MGB MG 6
AngliaGT 1978 Datsun B210 - Where Do I Go From Here? Other Cars 11
R ?'s re 1978 Midget MG 3
KLUTZ MGB-GT 1978 fuel tank.. compatible with my 74.5 GT? MG 6
J Spitfire Current Leakage, 1978 Spitfire Triumph 14
C MGB Radiator fans - 1978 MGB MG 11
JodyFKerr Spitfire 1978 Spitfire 1500 Triumph 32
M 1978 MG Midget 1500 Original Paint Color Options Spridgets 11
J Electric choke-MG Midget 1978 Single Weber Spridgets 4
dpcsix 1978 scca nationals champ Spridgets 8
dpcsix AH scca 1978 nationals champion Austin Healey 0
J Windshield washer 1978 midget-bag on fender system Spridgets 0
regularman Its a 1978 and I want it. Spridgets 23
J Firing order 1978 Mg Midget 1500 Spridgets 7
Sarastro Thoughts on a 1978 Mercedes 450SL Other Cars 3
J Where is the brake light switch? 1978 Mg Midget Spridgets 9
J Oil pressure gauge -on 1978 Mg midget 1500 Spridgets 6
B Will a 1978 Midget Steering Wheel fit a '79 Midget Spridgets 6
M MGB 1978 MGB Headlight Ring MG 8
