Re-awakening an Engine - Not Quite the Usual ?
dklawson
I now have the donor 1500 for my project Spitfire. According to dates written on the oil filter the engine was last run in 1997.
I will be using the alternator, distributor, flywheel/clutch, water pump, intake/exhaust manifolds, and carb off the old engine. The plugs will be new and I will set the valves, do an oil change, and all the regular mundane stuff.
The donor engine turns over freely by hand so I'm not worried that the rings are stuck or bores rusted. However, short of tearing the engine apart, what other things should I look at prior to restarting the engine?
Mickey Richaud
For a very good description, go to Tony Barnhill's site (it's still active), theAutoist.com. Look for the technical/tips section and click on "Awakening a sleeping MGB". It's about the best out there.
Mickey
TDHoward
just because it turns over doesn't mean something isn't stuck.
Err on the side of caution, and once you get the oil changed,
take out the dizzy and run the oil pump a while with a drill motor.
Make sure the oil is getting to the top, and you can see it coming up and out.
Take out the plugs and pour some thin oil, diesel, marvel mystery oil or etc. in the cylinders and let it soak a couple of days. This will creep into gum, varnish and light rust and loosen up any sticky rings.
Turn it over a few times with no plugs, to spread out the lube before trying to start it.
Just precautionary
DougF
I would pull the oil pan while the engine is out of the car. You clean out any sludge that may have accumulated and pull a main bearing and a couple rod bearing caps to inspect for wear.
The cost is minimal and could save a lot of time.
tdskip
Have you done preliminary compression testing on the cylinders yet? They will change, usually for the better, once the engine has gone through some heat cycles but it would be good to know that you've got some level of compression. (sorry if you already did that on a separate thread)
dklawson
dklawson
To those who asked, I haven't done anything to the engine yet. In spite of the number of times I've worked on engines, I don't own an engine stand or I probably would already have the pan off. Perhaps I will be able to "get by" leaning the engine over sideways to remove the pan.
I was wondering about the Marvel Mystery Oil or diesel/kerosene in the bores to soften deposits around the rings.
I believe I still have a drive I made for the GT6 which I'll use to run the pump by drill prior to cranking.
I'll read Tony's site soon. Based on the advice above I'll plan on ordering a few items like a rear main seal and pan gasket, and while I'm waiting on the parts I'll put a little MM oil in the bores and perhaps kerosene in the sump so when I do remove the pan the goo will hopefully be easier to remove.
I'm afraid the compression tests will have to wait until the engine is bolted into something.
Thanks for all the advice.
Basil General Tech Awakening a Sleeping MGB MG 5
ckeithjordan TR2/3/3A Awakening a Slumbering TR Triumph 16
WillR MGB Awakening grumbles. MG 21
apbos Awakening the Smooth Case Transmission Spridgets 7
rick_ingram MGB Awakening my 1978 MGB - No Results MG 4
MCNX_BFF Awakening the Beastie...trying to! Triumph 41
G Girls Awakening Austin Healey 2
macino62 awakening.... Triumph 5
vping Awakening a sleeping B MG 7
Darwin Need help awakening a B MG 2
tony barnhill Awakening a Sleeping MG MG 3
mctriumph For Sale Tr7 engine Triumph Classifieds 0
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
D A distributer question on the 1275 engine. Spridgets 7
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
