1978 MG Midget 1500 Original Paint Color Options
Midget78
Hello to all my fellow Mg buddies out there. Well, Im waiting on getting my 78 MG Midget 1500 back from the shop after having to put her in there so the new Weber DGV carb can get tuned in properly. She was running very rich and clearly needed some different jets, emulsion tubes, air tubes to get her running properly. Its tough sometimes handing them over to someone else to have the fun of working on them. This guy I found was a well known recommended MG mechanic so it made the desision a bit easier. Anyway and on to my question, this car has the original paint on it and spent quite a few years in the Texas sun. Now she is back home in northern Ohio in the salty, snowy roads. The paint is chipped and severly weathered needing redone. My plan is to strip it all down and get it primered. The question I have is where to find the original colors for this year of Mg as I would like to possibly change the color but stay within the world of MG paint schemes. Any help on point me in the right direction is appreciated.
bob67bgt
Changing colors is not a easy process. It always looks crappy when someone changes the color and sprays the engine bay black. If you are going to change colors be prepared to do it correct. Its like putting on a new suit and not changing your shorts if the jambs,trunk, and engine bay are not up to the rest of the job. I hope it all works out to your satisfaction. Bob
M
Midget78
Thanks for the web page with the paint schemes. Currently it is a dark red almost wine color but the sun has really done a number on it so its hard to tell what the original color actually was. I agree with the guy that commented about doing it right and getting in the engine compartment and places like that. Maybe I will just stick to the color I think its closest to and finish the outside only. I just know I need to do something cause its a great little car and the body is solid, its just with the paint faded, chipped, with lite surface rust at spots it looks like a real hunk of junk. Plus these northern Ohio winters dont do any justice to a car with the road salt. Thanks for the feedback.
JPSmit
inside of the trunk would tell you also
Jer
You drive your midget in Ohio winters ? OUCH !! the best thing you could do is put her away in the garage every fall before 1st snow until spring after the roads are clear of sand & salt... :smile: If you have to drive her in the winter, please get a proper undercoating done (oil spray / dripless undercoating) - As you mention winter driving will make that dry Texas steel disengrate in no time at all... seen it happen on many clean sound cars that came from the southern states to where I am in northern ontario, they will rust at an alarming rate seeing that the sheetmetal has never been exposed to such extreme conditons!
M
Midget78
Jer, I only drive it in the winter when it turns into one of those rare spring days or serious emergency. I always take it and spray it off when it does go out on the road knowing the salt will destroy this car. Has anyone used that oil coating stuff they sell in the british car parts catalog. I forget the name of it but its like furniture polish with an oil base and is applied like wax. I got a catalog in the mail the other day that had it advertised but never heard of it before. I'll have to check and see the name of it.
waxoyl (sp)?
place up the road from me just hung out a sign advertising the stuff. if it is anything like the tar the factory used underneath these cars it has to be good.
mark
JPSmit
I recall from the Automobile Protection Agency ( https://www.apa.ca/template.asp?lang=english ) who publish a book called LemonAid recommended Krown as the only rust company worth going to. we had my wife's car done - will get mine done next month and I expect to take Ms Triss there even though she will never be winter driven - just some more insurance for not too much money
tweety
Re: 1978 MG Midget 1500 Original Paint Color Optio
I would not worry too much about black trim/engine compartment on a '78. If it's ever a true classic, then you can make the paint match.
I think a mismatched but close color (original color inside doors, under hood, but close match outside) looks worse than the black under hood etc.
M
Midget78
Hey guys. Actually I probably shouldnt asume its only guys into this stuff. Anyway, "Waxoyl" is the stuff as Silent Unicorn said. It looks like applying it would be done using a wax pad or rag but I could see that as being very difficult without a spray system for good coverage. But I dont know how thick the liquid is for application? Im thinking about giving it a shot as the cost wasnt to bad. Any extra protection under the car can only make things better. Specially in this northern Ohio climate where old man winter has no mercy on any car.
J Firing order 1978 Mg Midget 1500 Spridgets 7
J Oil pressure gauge -on 1978 Mg midget 1500 Spridgets 6
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
Kleykamp For Sale 1978 MG Midget Best Offer Spridgets Classified 0
Kleykamp For Sale 1978 MG Midget photos added Spridgets Classified 0
Kleykamp For Sale 1978 MG Midget project or parts Spridgets Classified 0
TomR 1978 MG Midget with Points Distributor Spridgets 4
L 1978 mg midget seat belt replacement Spridgets 3
R ?'s re 1978 Midget MG 3
J Electric choke-MG Midget 1978 Single Weber Spridgets 4
J Windshield washer 1978 midget-bag on fender system Spridgets 0
J Where is the brake light switch? 1978 Mg Midget Spridgets 9
B Will a 1978 Midget Steering Wheel fit a '79 Midget Spridgets 6
J 1978 MG Midget For Sale [florida area] MG 0
M For Sale 1978 MGB MG Classifieds 0
M 1978 London Taxi Passengers Other British Cars 1
G MGB 1978 MGB clutch is out..! MG 39
R For Sale Time Capsule 1978 MGB MG Classifieds 1
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
S MGB 1978, replacing the clutch. MG 3
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
M MGB 1978 mg fuel smell MG 23
M Hello again. I have a 1978 Triumph spitfire. Triumph 17
S MGB Newbie 1978 MGB questions MG 11
M Spitfire need a crankshaft pulley for 1978 Spitfire Triumph 0
B MGB anyone have a photo of a 1978 MGB dashboard to left of steering and console ? MG 9
B MGB 1978 MGB 2 wires hanging under the dash to the .. MG 4
rovernut 1978 with black seats..biscuit interior..Original? MG 2
rick_ingram MGB Wheel Upgrade - 1978 MGB MG 6
AngliaGT 1978 Datsun B210 - Where Do I Go From Here? Other Cars 11
rick_ingram MGB Awakening my 1978 MGB - No Results MG 4
KLUTZ MGB-GT 1978 fuel tank.. compatible with my 74.5 GT? MG 6
J Spitfire Current Leakage, 1978 Spitfire Triumph 14
C MGB Radiator fans - 1978 MGB MG 11
JodyFKerr Spitfire 1978 Spitfire 1500 Triumph 32
dpcsix 1978 scca nationals champ Spridgets 8
dpcsix AH scca 1978 nationals champion Austin Healey 0
regularman Its a 1978 and I want it. Spridgets 23
Sarastro Thoughts on a 1978 Mercedes 450SL Other Cars 3
M MGB 1978 MGB Headlight Ring MG 8
J Spitfire 1978 Spitfire Distributor Amplifier Module Triumph 0
J Spitfire 1978 Spitfire Horn trouble shooting Triumph 10
M 1978 Eleectrical issues MG 17
M MGB Drive Shaft U-Joint, 1978 MGB MG 4
L Paint name for 1978 MG 4
Guinn draining and refilling coolant, 1978 B MG 9
N MGB 1978 MGB Coolant Level Checking MG 3
G MGB 1978 mgb courtesy light needed MG 1
G MGB windshield washer system 1978 MGB MG 9
D Trying to get back working on the 1974 Midget Spridgets 11
