wkilleffer
Hey everyone,
I'm having a little trouble with the clutch on my 1974 MGB. I tried to drive it the other day, and there was no pressure in the clutch pedal. I'd changed out the slave cylinder about a year ago, but didn't change the hose at that time. The hose is old, and it appears to have perished. The slave appears to be in fine fettle and only slightly dirtier than it was when fitted.
The trouble is that I can't get the old hose out of the car. It was a simple job to unfasten the slave cylinder and unscrew it from its respective end of the slave hose. But getting the hose off the end of the metal piping from the master cylinder is proving to be more of a challenge.
Based on the new hose, that end of the old one requires an 18mm wrench, which I have in combination form. I know which direction the thing's threaded, so I know how to pull. Is this just a matter of pulling like h-e-&-# and hoping for the best? I'd like to get the car back on the road this afternoon if possible.
Thank you,
-Bill
Thank you,
-Bill
