beachbumbarry
I have a 51 MG-TD that was a basket case when I bought it and had a lot of missing parts. In order to make a good running car I bought a 72 MGB and installed the drive train in the TD. I put the 72 disk breaks on the front. I don't have the parts to use the floorboard break/clutch setup. The clutch is now hyd operated.
Has anyone installed the MGB break / clutch master cyl set-up in a TD? I have all the MGB master cyl parts and it looks like there is enough room above the driver leg area.
Thank you for any advise / comments.
BarryE
BarryE
