1500 clutch release bearing removal -how to do it?
Thor
I have a 1500 with a clutch release bearing that I need to replace. I've gotten the sleeve/release bearing out of the bell housing but am wondering how to get the release bearing off of the sleeve.
The manual speaks about some special tool no. 1BG1270 which I have no idea what it might be or where to get it. Does anyone have suggestions as how to get it off and then put a new one on.
Thanks
Bugeye58
It's a press fit on the sleeve. Getting the old one off is no problem, just support the back side of the bearing, and press it off.
Be very careful when installing the new one, pressing only on the inner sleeve of the bearing. You may have to fab up a small piece of tube to reach, but whatever you do, don't press on the fat part of the bearing. You'll crush the housing and destroy the bearing. After pressing a little bit, stop and make sure the bearing is free to rotate. Continue until it's fully seated.
Jeff
scubabatdan
I have a 12 ton shop press for doing bearings, and I use a cold chisel to take the old one off with. You can get one cheap for 99.00 here:
https://www.northerntool.com/webapp/wcs/s...415&R=200326415
It is a useful investment and sure you may not use it much, but when you need one they are great to have around.
Hope this helps ya.
Ɛan
sparkydave
The guy I took mine to (William Whitmoyer of Old Sports Car Garage) just rigged up something where he used a bearing splitter to support the old bearing, then used an impact socket with his hydraulic press to drive the sleeve out. Then he used another impact socket the size of the bearing's inner race to press it on.
sparkydave 1500 clutch master Spridgets 4
RichBall Observations and impressions for bleeding the 1500 clutch system Spridgets 5
dklawson Spitfire Clutch Kit Preference - 1500 Spitfire Triumph 3
JPSmit 1500 Clutch hose question Spridgets 8
T Could someone measure a 1500 clutch slave pushrod? Spridgets 15
R 1500 midget clutch inspection? Spridgets 3
pipercollins Spitfire Spit 1500 Clutch Issues Triumph 24
G 79 midget 1500 clutch? Spridgets 5
A MIDGET 76 1500 CLUTCH SLAVE CYLINDER Spridgets 1
N Spitfire How to remove fan clutch on 1500 Spit Triumph 6
Steve P. Midget [1500] clutch threshold? Spridgets 4
D 79 Clutch Midget 1500 eng. Spridgets 7
S 1500 CLUTCH QUESTION. Spridgets 4
G Midget 1500 Water Pump / Fan Clutch Question Spridgets 6
G 1500 Midget Clutch & Transmission Question Spridgets 7
P 1500 Water Pump/Fan Clutch Spridgets 3
jcatnite 1500 Clutch Spridgets 5
C LCB header with 1500 single carb inlet manifold Spridgets 1
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
G Spitfire Spitfire 1500 differential whining Triumph 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
G T-Series 1955 mgtf 1500 lites MG 5
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
G 79 Midget 1500 overheating Spridgets 2
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
R Spitfire Spitfire 1500 Triumph 3
B MGA Solution! 1600 harness in a 1500 MG 1
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
A 76 Midget 1500 Oil filter Spridgets 6
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
M Rocker feed kit for 1500 from Victoria British Spridgets 0
sparkydave 1500 battery cable colors Spridgets 1
GS67 1500 Operating Temperature Spridgets 2
doc50 Nash Metro w/MGA 1500 discrepancy... Other British Cars 2
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
