RichBall
There have been a few threads posted here recently on problems bleeding the 1500 Midget’s Hydraulic clutch system. Since I just recently had similar issues I thought I would post my observations, impressions and solutions.
A few weeks ago I went out to take the Midget for a spin up to the store and was greeted by a non functioning clutch pedal. After investigating a bit I came to the conclusion that the slave cylinder had finally given out on me. I ordered an original Lockheed rebuild kit from Peter C., did a light honing pass to clean it up and rebuilt it. After getting everything back in and buttoned up I called for my lovely assistant Susan (wife) and we set about trying to bleed it. Trying is the key here. We spent an hour plus and at least a pint of LMA trying to get it working with no luck.
I see two areas in the system that contribute to problems bleeding in the traditional way.
The first problem I needed to over come was the air that was trapped in the arch of the line connecting the master to the slave. On the 1500 the line is a transparent tube that arches up before heading down to the slave. The problem I was having was that the volume of fluid being sent through the line was not sufficient to move the air down the vertical rise. The air bubble would slide up past the fluid and back to the high point of the arch. Phil Jones came to my aid here by loaning me his Eezibleed system. This pressurized bleeder worked great and was able to move enough fluid under pressure to move the air bubble out of the line. Unfortunately it took up residence in the slave cylinder.
The second problem I came across has to do with the bleed valve on the slave. First off it is located slightly below the high point of the cylinder so any trapped air can not flow out easily even with the rear of the car raised above the front. Adding to this is the limited space to rotate a wrench placed on the bleed valve. You’re only able to open the bleed valve a slight amount to release the fluid with a flair nut wrench and hose on the bleed valve. This low flow was not enough to force the air out of the slave. What I found worked well was to use a 7/16 box wrench that could slide off over a hose on the bleed valve so I could reposition the wrench and rotated it again several times. This allowed me to open the valve much wider. This in combination with the pressure of the Eezibleed to move the fluid cleared all the air that was still trapped in the slave.
From my experience the most successful way to bleed the clutch on the 1500 Midget is to have a high fluid flow rate so the air in the system gets caught up with the fluid flow and pulled out along with it.
Sorry if this was long winded, but I thought it might be useful to others that are having the same problem.
Rich Ball
’76 Midget
Rich Ball
’76 Midget
