Jim_Gruber
First pump of the pedal goes almost all of the way to the floor. Second pump firm pedal. Third pump all of the way up. This appears to have been a new Master Cylinder on Bugsy IV along with all new Wheel Cylinders. I added new hoses all around. Shoes feel about as tight as I can make them. Have bled two or three times. Today by myself with help from Mity-Vac. Is there anything with the pedal adjustment screw I need to worry about. Not going all of the way back and allowing MC to refill properly. Looks ok visually and there is far more than 5/32" of pedal movement before brake rod begins to move. other than finding a Brake Bleeding Assistant today what am I missing. I've never had an issue with bleeding brakes before.
