Hey all,
Another question from your South Carolina Healey nut.
I finished redoing my brakes and in process of bleeding
them. Thought I would get smart and bought one of those
pressure bleeders that you hook up to the bleeder screw
and force any air through the system and out the master
cylinder. Well, works great on the rear brakes but the
front brake bleeder screw has the small ball bearing in
the screw which acts as a valve. Guess what, won't allow
me to try to force fluid up through it as obviously it is
"seating" and closing off the bleeder screw. Know I can
bleed the front brakes the old fashioned way but could I
just remove the ball bearing as did check and can screw the
bleeder screw down to shut off the flow of brake fluid ?
I understand that it is a check valve probably to help keep
dirt, etc from entering the brake hyd system but like most of
us, this BN1 will not be seeing any inclement weather unless
I get caught in the rain.
Thanks,
Mike
Thanks,
Mike
