Bleeding brakes
Guinn
Would someone please tell me the location of the Pressure Differential Actuator? Just got my new brake hoses from Tony and will install them probably Monday.
Guinn
Is that the white plastic thing under the master cylinder?
tony barnhill
Great Pumpkin - R.I.P
I think you're talking about that funny shaped thing on the inner fender to which all your brake lines run (usually called the Pressure Failure Switch & Body Assembly)...When you're bleeding your brakes, you should disconnect the wiring to the pressure failure switch & then unscrew the switch out of the body about 3 turns so it doesn't make contact inside the actuator.
I think...
My pressure fail switch is screwed into the bottom/center of the master cylinder... White plastic with a metal plunger.
tony barnhill
You have a boosted brake system - he doesn't.
Sorry, I thought he was asking about the same 78 B he mentioned in the other thread.
tony barnhill
Oh, well if he is - I'm dead wrong! & the actuator is up inside the master cylinder...but you still disconnect the wiring & back the switch off.
tony barnhill
Only 1 MG - JEEZ! Ya gotta get with the program!
fundytides Bleeding Lockheed Brakes on 1951 Vanguard Other British Cars 11
C TR2/3/3A bleeding brakes Triumph 11
dklawson Spitfire Bleeding Herald Brakes [similar to Spit] Triumph 9
Jim_Gruber Brakes and Bleeding Spridgets 16
oxford Bleeding Brakes! Up-date. Austin Healey 0
oxford Bleeding Brakes! Austin Healey 25
F Spitfire Bleeding Rear Brakes - Ran Into Issues Triumph 7
T Spitfire Bleeding brakes Triumph 6
B Bleeding BJ7 brakes Austin Healey 9
K Problems with Bleeding the Brakes onan XKE? Jaguar 2
tahoe healey Bleeding the bloody brakes again Austin Healey 10
tahoe healey re bleeding brakes. Austin Healey 5
pkmh Bleeding brakes Austin Healey 18
Lynn Kirkpatrick Bleeding dual system brakes & how do they work? Restoration & Tools 5
bcbug Bleeding Brakes Spridgets 2
drooartz Help -- first time bleeding of clutch/brakes Spridgets 8
chicken bleeding the brakes Austin Healey 9
bighealeysource bleeding the brakes on my BN1 Austin Healey 4
bighealeysource bleeding the brakes on a BN1 Austin Healey 15
WillR bleeding brakes MG 18
C What was that tool for bleeding the brakes? Spridgets 3
RickB Bleeding dual circuit brakes? Spridgets 12
SCguy Bleeding Brakes ? Triumph 10
O TR6 Bleeding TR6 Brakes Triumph 2
jlaird Bleeding brakes Spridgets 8
Monark192 Bleeding Brakes MG 12
delisaj Bleeding the brakes-- won't work.. help! Triumph 4
SCguy TR4/4A Still bleeding my brakes on my TR4!!! Triumph 7
SCguy Bleeding Brakes tips? Triumph 7
R bleeding de brakes Austin Healey 10
B Help Bleeding the Brakes Austin Healey 13
R tool for bleeding brakes? Rover / Land Rover 3
F Bleeding Front brakes MG 11
S Bleeding the Brakes Austin Healey 10
Frameman 1949 Brake Bleeding Austin Healey 0
KVH General Tech TR4A Brake Bleeding Triumph 5
Crankshaft TR2/3/3A Bench Bleeding Triumph 8
Govtslug TR6 Brake Bleeding Triumph 58
TRclassic3 TR2/3/3A Odd observation when bleeding Triumph 5
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
R TR2/3/3A Bleeding the Slave Cylinder Triumph 118
KVH General Tech Bleeding Brakes—Venturi/Compressor Triumph 8
N Need brake bleeding advice Spridgets 6
tahoe healey DIY Extension for Clutch Bleeding Austin Healey 23
F TR2/3/3A Bleeding Technique Triumph 46
K Bloody "bleeding" issue Austin Healey 55
bugedd Bleeding clutch Spridgets 2
F TR2/3/3A Bleeding Hydraulics Triumph 9
S Help with clutch bleeding on BJ8 Austin Healey 7
