Bleeding Brakes
Monark192
Here we go again - after learning from you helpful folks that persistance is the key when bleeding brakes and getting the job done on the now sold '75, I thought I could manage it the next time around on the '74.5. Well, it aint working. The master is brand new, installed and full of fluid. I tried and tried to get the rear blakes to bleed with no luck I moved to the fronts in search of a little acomplishment and joy, I can hapily pump fluid out of each caliper. Back to the rears, I even tried removing the brake line from the cylinder to make sure there isn't a blockage downstream. Still nothing. I understand (I think) that is is a dual line system but am confused as to how the master will only pump to the fronts. Is there a trick to getting it going??
Sorry for the long ramble (but I do feel a little better for it /bcforum/images/%%GRAEMLIN_URL%%/crazy.gif)
Keoke
HI your problem is in the Master Cylinder. Since it is new I would return it for a replacement. However, make sure you have the correct free play in the clutch pedal.--Fwiw--Keoke
Bruce74B
Or might it be a clog or a pinch UPline from the rear brakes... in the rear brake line somewhere? Disconnect the line where is goes over the axle and see if you have hydraulics there. Then work your way back to the MC and see if it pumps fluid out into the line.
Bruce
jlaird
I would suspect a line problem as well and would do as Bruce suggests. One step at a time.
ecurie_ecosse
As they say "one step at a time." It's a beastly job and there are no short cuts. /bcforum/images/%%GRAEMLIN_URL%%/eek.gif
Stuart.
Platinum
Yes! Look to the flex-line at the diff. Loosen it at the chassis side and push the pedal a few times... I bet you'll get fluid. The flex-line can swell internally and not allow fluid to get to the rear cylinders. Cheap fix.
Other possibility is the hydraulic "switch" on the left inner wing: made to bias pressure to the working side of the system in case of failure. But check the flex hose first!
PeterC
Did you check that the shuttle is centered in the PWDA? Remove switch, re-center shuttle, install switch. You "should" be OK.
Peter C.
Monark192
Monark192
I have removed the brake line where it exits the master cylinder to remove all possible downstream blockages. Still nothing comes out. Can the new cylinder be bad like this?
PeterC
Hmmm.... I don't have one in front of me, but is the pushrod adjustable? Is it adjusted too tight, no freeplay? Maybe the port isn't opening. And, yes, unfortunately new cylinders can be bad.
Peter
Platinum
It's ~possible~ the front section of the M/C is airlocked (i.e. not hauling fluid into it due to air blocking it), bench bleeding it prior to installation would relieve this. But it really sounds as if the M/C was pre FUBAR'd. Rarely will a M/C *not* pump thru both chambers after the second pedal stroke.
Pushrod on this'n isn't adjustable, IIRC.
Bumble_Bee
I just replaced my M.C. and all of the wheel cylinders as well as the brake shoes and all of the lines. It was very frustrating for sure to get all of the air out. But out of frustration and thought I did this. I adjusted the brake shoes all the way out so the wheels would not turn, THEN I bled the system. My theory is that there is more pressure to the cylinders when there is not movement in the wheel cylinders and therefore more fluid flow to the bleeders. I did this along with the tube to the baby food jar of fluid and a 1/2 hour later viola!!! Make sure to go to each wheel and re-adjust the brake shoes. It worked great for me! Larry
Platinum
Setting the shoes to correct adjustment then pulling the handbrake will do the same thing, FYI.
fundytides Bleeding Lockheed Brakes on 1951 Vanguard Other British Cars 11
C TR2/3/3A bleeding brakes Triumph 11
dklawson Spitfire Bleeding Herald Brakes [similar to Spit] Triumph 9
Jim_Gruber Brakes and Bleeding Spridgets 16
oxford Bleeding Brakes! Up-date. Austin Healey 0
oxford Bleeding Brakes! Austin Healey 25
F Spitfire Bleeding Rear Brakes - Ran Into Issues Triumph 7
T Spitfire Bleeding brakes Triumph 6
B Bleeding BJ7 brakes Austin Healey 9
K Problems with Bleeding the Brakes onan XKE? Jaguar 2
tahoe healey Bleeding the bloody brakes again Austin Healey 10
tahoe healey re bleeding brakes. Austin Healey 5
pkmh Bleeding brakes Austin Healey 18
Lynn Kirkpatrick Bleeding dual system brakes & how do they work? Restoration & Tools 5
bcbug Bleeding Brakes Spridgets 2
drooartz Help -- first time bleeding of clutch/brakes Spridgets 8
chicken bleeding the brakes Austin Healey 9
bighealeysource bleeding the brakes on my BN1 Austin Healey 4
bighealeysource bleeding the brakes on a BN1 Austin Healey 15
WillR bleeding brakes MG 18
C What was that tool for bleeding the brakes? Spridgets 3
RickB Bleeding dual circuit brakes? Spridgets 12
SCguy Bleeding Brakes ? Triumph 10
O TR6 Bleeding TR6 Brakes Triumph 2
jlaird Bleeding brakes Spridgets 8
delisaj Bleeding the brakes-- won't work.. help! Triumph 4
SCguy TR4/4A Still bleeding my brakes on my TR4!!! Triumph 7
Guinn Bleeding brakes MG 9
SCguy Bleeding Brakes tips? Triumph 7
R bleeding de brakes Austin Healey 10
B Help Bleeding the Brakes Austin Healey 13
R tool for bleeding brakes? Rover / Land Rover 3
F Bleeding Front brakes MG 11
S Bleeding the Brakes Austin Healey 10
Frameman 1949 Brake Bleeding Austin Healey 0
KVH General Tech TR4A Brake Bleeding Triumph 5
Crankshaft TR2/3/3A Bench Bleeding Triumph 8
Govtslug TR6 Brake Bleeding Triumph 58
TRclassic3 TR2/3/3A Odd observation when bleeding Triumph 5
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
R TR2/3/3A Bleeding the Slave Cylinder Triumph 118
KVH General Tech Bleeding Brakes—Venturi/Compressor Triumph 8
N Need brake bleeding advice Spridgets 6
tahoe healey DIY Extension for Clutch Bleeding Austin Healey 23
F TR2/3/3A Bleeding Technique Triumph 46
K Bloody "bleeding" issue Austin Healey 55
bugedd Bleeding clutch Spridgets 2
F TR2/3/3A Bleeding Hydraulics Triumph 9
S Help with clutch bleeding on BJ8 Austin Healey 7
