It seems every time I go to bleed a braking system, I run into trouble. Here's the details:
I am trying to get a 79 Spitfire back on the road after sitting for something like 5-10 years. When I got the car there was no pedal pressure, so I pulled the m/c and rebuilt it over the winter. Today I:
*Reinstalled the m/c and started bleeding at the right rear wheel cylinder - got nothing but a few dribbles of fluid.
*Moved to the right front caliper and bled - bled easily, getting clear air-free fluid
*Moved to the left front caliper and bled - Again, bleeding perfectly
*Tried the left rear wheel cylinder - nothing, not even a dribble.
Now, my first thought was that the wheel cylinders where seized and not letting the fluid flow though, so I've pulled both of them and will rebuild over the next week. However, I got curious I and tried pushing the pedal with both rear wheel cylinders removed just to see if I could get some fluid to flow out of the lines. Well, I was pretty surprised to see nothing! So I did a quick inspection of the lines and didn't find any kinks or crimps.
So now I got thinking...When I ran into this same issue on my MGB last summer, it turned out to the a pressure differential switch that had been tripped, except on the MGB the switch is located right on the m/c itself. So my question is; does the Spitfire have a pressure differential switch on the braking system? If so, where is it? And most importantly, how can I reset (or bypass) it?
Any help is greatly appreciated, this is the only thing keeping me from being able to take the car out for a test run!
