bleeding the brakes on my BN1
bighealeysource
Bronze
Hey all,
A few weeks ago everyone was good enough to chime in on my
rear brakes rebuild, brake bleeding issues, etc. Well, I
have now bled my brakes so many times I feel like a vampire !
I've tried the new fancy tools and the old fashioned way
and still have a mushy pedal. I'm not getting any air in
the clear plastic bleed tubing and put everything back together and still mushy pedal. Used Norm Nock's Technical articles
and the service manual and still the above. When I am
driving and if I pump the brake pedal, it gets better but
still not like it was before yours truly replaced the rear
wheel cylinders. HELP - any suggestions on what to try
next ?
Thanks,
Mike
BOBBYR
Hi Mike,
Sounds like you've been having fun.Bleeding brakes can be pretty tricky.Please tell me the procedure you are using to bleed this system and I will try to help.You might want to PM me and it might be easier to explain.
Bobby R
Dave Richards
Lately, we've taken to pushing the fluid through from the master cylinder with a garden sprayer set up to be a pressure bleeder. On the last one, we had similar results to what you're describing and it turned out to be a bad master cylinder. It wasn't sending any fluid to the rear wheels.
healeynut
bighealeysource said:
Hey all,
next ?
Mike -
I know this sounds like a retarded question but did you mechanically adjust the shoes both front and back?
Even if your system is bled, you will have a mushy pedal unless your shoes are adjusted properly... otherwise they just back too far off the drum then you get a mushy pedal when (typically) only three of the four brakes is making contact & you have to pump to get the fourth up to the drum. This will feel just the same as air in the system.
bighealeysource
bighealeysource
Bronze
Hey y'all,
Thanks for everyone getting back so quickly. I bled them starting with the
right rear and progressing as per the factory and Norm Nock's recommendations.
Attached a bleed tube to the bleed valve with the end in a container partially
full of fluid. Pumped the brake pedal - usually about 8+ times and kept it
down on the last stroke - until no air showed in the fluid. Made sure to keep the master cylinder full of fluid too. Tightened the
bleed screw back up and went on to the next wheel, etc. I did adjust the
brakes per Norman's tech article but as Alan said above, maybe I do not have
them adjusted properly. Particularly the front since you have to adjust both sides. I did adjust so the drum was just turning free of the brake shoes
and not binding but maybe I need to adjust a bit more. Suggestions as to
how much contact the shoes should be making when adjusting ? Also, I have
new brake linings coming from Austin Healey Spares ( thanks for the tip Alan)
so my current linings are pretty worn.
Thanks,
Mike
bighealeysource bleeding the brakes on a BN1 Austin Healey 15
fundytides Bleeding Lockheed Brakes on 1951 Vanguard Other British Cars 11
C TR2/3/3A bleeding brakes Triumph 11
dklawson Spitfire Bleeding Herald Brakes [similar to Spit] Triumph 9
Jim_Gruber Brakes and Bleeding Spridgets 16
oxford Bleeding Brakes! Up-date. Austin Healey 0
oxford Bleeding Brakes! Austin Healey 25
F Spitfire Bleeding Rear Brakes - Ran Into Issues Triumph 7
T Spitfire Bleeding brakes Triumph 6
B Bleeding BJ7 brakes Austin Healey 9
K Problems with Bleeding the Brakes onan XKE? Jaguar 2
tahoe healey Bleeding the bloody brakes again Austin Healey 10
tahoe healey re bleeding brakes. Austin Healey 5
pkmh Bleeding brakes Austin Healey 18
Lynn Kirkpatrick Bleeding dual system brakes & how do they work? Restoration & Tools 5
bcbug Bleeding Brakes Spridgets 2
drooartz Help -- first time bleeding of clutch/brakes Spridgets 8
chicken bleeding the brakes Austin Healey 9
WillR bleeding brakes MG 18
C What was that tool for bleeding the brakes? Spridgets 3
RickB Bleeding dual circuit brakes? Spridgets 12
SCguy Bleeding Brakes ? Triumph 10
O TR6 Bleeding TR6 Brakes Triumph 2
jlaird Bleeding brakes Spridgets 8
Monark192 Bleeding Brakes MG 12
delisaj Bleeding the brakes-- won't work.. help! Triumph 4
SCguy TR4/4A Still bleeding my brakes on my TR4!!! Triumph 7
Guinn Bleeding brakes MG 9
SCguy Bleeding Brakes tips? Triumph 7
R bleeding de brakes Austin Healey 10
B Help Bleeding the Brakes Austin Healey 13
R tool for bleeding brakes? Rover / Land Rover 3
F Bleeding Front brakes MG 11
S Bleeding the Brakes Austin Healey 10
Frameman 1949 Brake Bleeding Austin Healey 0
KVH General Tech TR4A Brake Bleeding Triumph 5
Crankshaft TR2/3/3A Bench Bleeding Triumph 8
Govtslug TR6 Brake Bleeding Triumph 58
TRclassic3 TR2/3/3A Odd observation when bleeding Triumph 5
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
R TR2/3/3A Bleeding the Slave Cylinder Triumph 118
KVH General Tech Bleeding Brakes—Venturi/Compressor Triumph 8
N Need brake bleeding advice Spridgets 6
tahoe healey DIY Extension for Clutch Bleeding Austin Healey 23
F TR2/3/3A Bleeding Technique Triumph 46
K Bloody "bleeding" issue Austin Healey 55
bugedd Bleeding clutch Spridgets 2
F TR2/3/3A Bleeding Hydraulics Triumph 9
S Help with clutch bleeding on BJ8 Austin Healey 7
