Bleeding the Brakes
Scot
Hi All,
I have had my BJ8 for about 1 1/2 years now and wish to bleed the brake lines(looks dirty and last change unknown) and replace with fresh fluid.
Two questions, first, what are the considerations if any when bleeding a system that shares fluid with the clutch system? Second, would Castrol fluid be OK with a DOT rating exceeding 3 or 4.
This would be my first attempt at this so I'm just asking the stupid questions first.
Scot
Blonde Healey Girl
Scot, In a feeble attempt to contribute to this forum what little knowledge I have gained while owning an LBC heres two tibits that may help. First ,on the bleeder screws, only use a box end wrench or flare nut wrench, mine used a 7/16". Open end wrenches will usually round off the nut. The other thing is, if they are rusty ,spray some "PB Blaster" on them to loosen the rust. (wear safety glasses because the spray has a nasty habit of hitting the bleeder then shooting back into your eye!)
As far as what type of fluid to use, check back in the forum, there is a good discussion on every kind of brake fluid know to man....
Blonde Healey Girl
CDK
BHG has given good advice. The bleeders breaking loose will be the first thing to overcome. PB BLASTER is good, (for all forum members)- if you can find it try AEROKROIL by Kano Products it is about the best spray\antirustbreaking lubricant I have ever used, you will not be disappointed.The box,tubing wrench or a deep socket is also a must. AT even a hint of rounding switch to a pair of vise grips, carefully lock them on the flats of bleeder screw and very slowly try to work loose. Sometimes a impact motion will work good. If you even think they are going to break off stop and think things over because the next step might be getting a new caliper. If all four bleeders come out conside this a major acompplishment. At this point do you self a favor and get four new ones (they are cheap)and Neversieze the threads before putting back together. Gravity bleeding is slow but real effective and you only need one person. Other wise get a friend and have them pump well you bleed. There are also pressure kits available.Good luck.
John Turney
Good advice above. Also, since the clutch and brakes share the same fluid reservoir, bleed the clutch too.
John, BN4
ThomP
Bleed it all, open each bleed screw and flush, including the clutch untill it all runs clear. Dot 4 only (unless your system has purple stuff in it then use Dot 5) We should ALL be in the habit of doing this every 2 years. Don't overtighten the bleed screws when done. The bleed screws have tapered seats and seal without a lot of heavy handed wrench work. It will make the job easier two years from now.
John Turney
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Scot:
By the way, where would the clutch bleed screw be located?<hr></blockquote>
It's on the clutch slave cylinder, which is on the right side of the bell housing. You should get the car up on jack stands or a rack (easier than taking out the transmission tunnel).
John, BN4
S
Scot
Thanks to those that responded to the brake bleeding question. The suggestions here will make the job a little easier and I know have saved me major problems!
ThomP
There was an article in one (or both) of the Healey club magazines that show how to make a special tool for reaching the clutch bleeder. It is made from a Craftsman 7/16 box end wrench. I made one, it didn't work. It would overlay the photo perfectly, but I couldn't figure out how it was any advantage. I found that a "stubby" 7/16 combination wrench works perfectly.
Louie
Castrol LMA is available at Pep Boys.
Allow no other brand to be used.
If Silicon fluid has been used (purple), check the archives.
fundytides Bleeding Lockheed Brakes on 1951 Vanguard Other British Cars 11
C TR2/3/3A bleeding brakes Triumph 11
dklawson Spitfire Bleeding Herald Brakes [similar to Spit] Triumph 9
Jim_Gruber Brakes and Bleeding Spridgets 16
oxford Bleeding Brakes! Up-date. Austin Healey 0
oxford Bleeding Brakes! Austin Healey 25
F Spitfire Bleeding Rear Brakes - Ran Into Issues Triumph 7
T Spitfire Bleeding brakes Triumph 6
B Bleeding BJ7 brakes Austin Healey 9
K Problems with Bleeding the Brakes onan XKE? Jaguar 2
tahoe healey Bleeding the bloody brakes again Austin Healey 10
tahoe healey re bleeding brakes. Austin Healey 5
pkmh Bleeding brakes Austin Healey 18
Lynn Kirkpatrick Bleeding dual system brakes & how do they work? Restoration & Tools 5
bcbug Bleeding Brakes Spridgets 2
drooartz Help -- first time bleeding of clutch/brakes Spridgets 8
chicken bleeding the brakes Austin Healey 9
bighealeysource bleeding the brakes on my BN1 Austin Healey 4
bighealeysource bleeding the brakes on a BN1 Austin Healey 15
WillR bleeding brakes MG 18
C What was that tool for bleeding the brakes? Spridgets 3
RickB Bleeding dual circuit brakes? Spridgets 12
SCguy Bleeding Brakes ? Triumph 10
O TR6 Bleeding TR6 Brakes Triumph 2
jlaird Bleeding brakes Spridgets 8
Monark192 Bleeding Brakes MG 12
delisaj Bleeding the brakes-- won't work.. help! Triumph 4
SCguy TR4/4A Still bleeding my brakes on my TR4!!! Triumph 7
Guinn Bleeding brakes MG 9
SCguy Bleeding Brakes tips? Triumph 7
R bleeding de brakes Austin Healey 10
B Help Bleeding the Brakes Austin Healey 13
R tool for bleeding brakes? Rover / Land Rover 3
F Bleeding Front brakes MG 11
Frameman 1949 Brake Bleeding Austin Healey 0
KVH General Tech TR4A Brake Bleeding Triumph 5
Crankshaft TR2/3/3A Bench Bleeding Triumph 8
Govtslug TR6 Brake Bleeding Triumph 58
TRclassic3 TR2/3/3A Odd observation when bleeding Triumph 5
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
R TR2/3/3A Bleeding the Slave Cylinder Triumph 118
KVH General Tech Bleeding Brakes—Venturi/Compressor Triumph 8
N Need brake bleeding advice Spridgets 6
tahoe healey DIY Extension for Clutch Bleeding Austin Healey 23
F TR2/3/3A Bleeding Technique Triumph 46
K Bloody "bleeding" issue Austin Healey 55
bugedd Bleeding clutch Spridgets 2
F TR2/3/3A Bleeding Hydraulics Triumph 9
S Help with clutch bleeding on BJ8 Austin Healey 7
