High altitude mixture observations
steveg
Just got back from Deadwood where it was fun to meet some of the folks on the Forum. There we drove at altitudes of 4500 - 5800 ft.
I'm running Normal UH needles in my HD8s. Referring to my Air/Fuel Ratio gauges, 11s to 12s were typical. 11 is just on the rich side of power; power is 12.1 - 12.8.
One warm day in traffic at a tunnel at 5800 ft, the plugs were loading up a little, but cleared up as speed was resumed.
I seemed to recall that some folks who live at high altitudes had been advised to use the rich UN needles and wanted to report back that my instruments told me otherwise.
FWIW at my normal altitudes of around 1000 ft, the car runs a little leaner in the 13s on the freeway.
vette
Steve, I don't have much altitude variation in my area of Pa. So I don't have a lot of experience with how altitude affects the Healey. But, I thought as the air gets thinner with altitude then the carbs would richen. Why then would anyone want to put richer needles in when they drive to higher altitudes? Or do I have it all wrong.
red57
Nope, you have it right vette. Higher altitude = less oxygen, so to compensate, you need to lean mixtures.
Steves experience is what I would expect. It's just that in most cases people don't have accurate A/F gauges to show it.
Dave
steveg
steveg
I posted this as I seemed to remember a certain person who lives at one of the higher elevations had been advised by a certain supplier to use the rich needles. I could be remembering wrong - backing up a general observation with data.
vette
Good data Steve. Thanks for sharing.
R General Tech High altitude adjustments Triumph 3
R High Altitude adjustments Austin Healey 3
H TR4/4A High Altitude Adjustments Triumph 11
Carlbanan56 MGB High beam problems MG 4
Carlbanan56 MGB High rpm problem MG 27
G High Oil Pressure Austin Healey 2
P TR2/3/3A British High Torque starter Triumph 6
MikeAH100M High Temp Engine Miss Austin Healey 2
Carlbanan56 MGB High resistance MG 2
Gatheringtree TR2/3/3A Faltering at high RPM and under load demand Triumph 34
S TR2/3/3A floundering At High RPM Triumph 29
M High-Torque Starter Austin Healey 10
Martinld123 High-Torque Starter Austin Healey 4
B TR4/4A High Torque Starter Wiring Triumph 9
LAW75 High-Pitched Noise Austin Healey 13
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
Hamish Racing General Tech Petrol/Gas with high ethanol Triumph 3
Taftster MGB Electric Gauges Read High, Any guesses? MG 5
B High-Torque Starter Rattling Noise Austin Healey 3
M 1275 too high? Spridgets 2
dougie Targa High Country 2021 Austin Healey 2
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
J Experience with High Ratio Steering Box? Austin Healey 15
R Speedo High Beam Warning Light Color Austin Healey 14
Lin Gear Reduction High-Torque Starters: Inertia or Pre-engaged? Austin Healey 4
M TR6 High Compression in One Cylinder Triumph 28
AUSMHLY 64 front end too high Austin Healey 14
Simmo TR2/3/3A High Oil pressure Triumph 11
D TR5/TR250 High oil pressure Triumph 5
B TR6 1970 High Back Seats for TR6 - Side bolste wires squabs neededr Triumph 3
bfitz TR6 72 TR6 clutch high engagement point Triumph 16
A MGA High beam indicator light not working MG 2
D TR2/3/3A Alternator dial runs high Triumph 5
steveg High quality hose clamps Austin Healey 3
R TR2/3/3A TR 3A running hot at high rpm Triumph 12
W Tachometer reads high when engine compartment heats up Austin Healey 3
77MidgetMkIV High Beam/Turn Signal switch issue? Spridgets 21
4tecdog Misfire at high revs Austin Healey 21
warwick-steve Steering high spot - midway Austin Healey 17
warwick-steve High compression head identification Austin Healey 16
J TR4/4A High Water marks? Triumph 5
John Turney Another High-Priced "100" Austin Healey 11
D High beam Lamp Spridgets 3
D 69 E Type High Idle Jaguar 9
B TR6 TR6 High Oil Pressure Triumph 20
M_Pied_Lourd TR6 J Type Overdrive High Pressure Filter Cap-Major Problem Triumph 6
2billydavies TR2/3/3A very high idle, timing perfect Triumph 7
GTP1960 TR2/3/3A High beam indicator malfunction Triumph 3
B mgb taking the high road Spotted 0
B '67 BJ8 to high Austin Healey 18
