MGB High beam problems
Carlbanan56
Member
Hi guys, I have been having problems with my left high beam. It has been working on and off for a time. One day it would work without problems. Other days it would just randomly shut off and not come on. Today I decided to fix what I fought to be just a corroded contact surface. After removing the bulb cover I checked the contacts and I had 12 volts at the bulb cables. Must be the lamp then! But when I checked the bulb to a sper 12 volts battery lit it up. This has gotten me very puzzled. If I have power to the cables and the bulb is working, why isn't lighting up when it's plugged in?
It's a 1975 MGB
Every suggestion and insight is greatly appreciated
Young and inexperienced
/Carl
YakkoWarner
My universal answer to these kind of gremlins is - check the grounding. A bad ground would let you measure 12V at the cable (from low or high beam to ground) because the meter draws almost immesurably small amounts of current - but a normal headlamp pulls around 3-5 amps of current and a bad ground won't pass that much current, hence no light.
On every B I ever owned I added ground wires to ALL the lamp fixtures. The headlamps already have a ground wire in that 3 pin plug that goes to the bulb, but the other end goes into those bundles of bullet connectors that are behind the horns...corrosion or dirt in there can cause you all sorts of headances. Thats where I'd start disconnecting and cleaning connections.
Carlbanan56
Carlbanan56
Member
That sounds lika probable cause. I will check this as soon as possible. Thank you so much
Sarastro
...... I have power to the cables and the bulb is working, why isn't lighting up when it's plugged in?
Because you have an intermittent bad contact between the socket and the bulb. If it was a bad ground, you would see the same effect on both the high and low beams, since they share the same ground conductor. So I don't think that's it,at least in this case. But, regardless, the suggestion of running solid grounds is a good one.
You might fix this by spraying electrical contact cleaner into the connector, or denatured alcohol if that's all you have, then push it on and off a few times. Might help, but it probably will not stay fixed unless you replace the socket.
Carlbanan56
Carlbanan56
Member
I checked the ground and as you predicted was it pretty weak ground. I used some sandpaper to make sure that the cables had good ground. This solved my issue, thank you!
R Speedo High Beam Warning Light Color Austin Healey 14
A MGA High beam indicator light not working MG 2
77MidgetMkIV High Beam/Turn Signal switch issue? Spridgets 21
D High beam Lamp Spridgets 3
GTP1960 TR2/3/3A High beam indicator malfunction Triumph 3
Tinkerman HIGH BEAM LIGHT Ground Wire Triumph 5
W BE ignition and high beam jewels... Spridgets 12
W BE ignition and high beam jewels... Spridgets 0
wkilleffer Adding relays to the low and high-beam circuits MG 10
Rob Glasgow High Beam Indicator Color - At last the answer Austin Healey 3
drooartz Moving high beam switch Spridgets 13
T High Beam Headlights Jaguar 1
C One High Beam doesn't work Triumph 5
mjobrien High Beam Switch Mounting [Dipper] Austin Healey 7
19_again Blue high beam indicator MG 8
D High Beam Indicator Always On Triumph 9
W high beam/engine light MG 7
T High-beam switch Triumph 2
M high beam light cover Spridgets 13
X no beam/ high beam! MG 6
Carlbanan56 MGB High rpm problem MG 27
G High Oil Pressure Austin Healey 2
P TR2/3/3A British High Torque starter Triumph 6
MikeAH100M High Temp Engine Miss Austin Healey 2
Carlbanan56 MGB High resistance MG 2
Gatheringtree TR2/3/3A Faltering at high RPM and under load demand Triumph 34
S TR2/3/3A floundering At High RPM Triumph 29
M High-Torque Starter Austin Healey 10
Martinld123 High-Torque Starter Austin Healey 4
B TR4/4A High Torque Starter Wiring Triumph 9
LAW75 High-Pitched Noise Austin Healey 13
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
Hamish Racing General Tech Petrol/Gas with high ethanol Triumph 3
Taftster MGB Electric Gauges Read High, Any guesses? MG 5
B High-Torque Starter Rattling Noise Austin Healey 3
M 1275 too high? Spridgets 2
dougie Targa High Country 2021 Austin Healey 2
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
J Experience with High Ratio Steering Box? Austin Healey 15
Lin Gear Reduction High-Torque Starters: Inertia or Pre-engaged? Austin Healey 4
M TR6 High Compression in One Cylinder Triumph 28
AUSMHLY 64 front end too high Austin Healey 14
steveg High altitude mixture observations Austin Healey 4
R General Tech High altitude adjustments Triumph 3
R High Altitude adjustments Austin Healey 3
Simmo TR2/3/3A High Oil pressure Triumph 11
D TR5/TR250 High oil pressure Triumph 5
B TR6 1970 High Back Seats for TR6 - Side bolste wires squabs neededr Triumph 3
bfitz TR6 72 TR6 clutch high engagement point Triumph 16
D TR2/3/3A Alternator dial runs high Triumph 5
