high beam/engine light
wigan
Member
Odd problem with my high beam/engine light. For some reason the blue beam light glass blew on me a couple of months back and the red engine glass went yesterday. The actual bulbs are still working.
I have tried to remove them but can't figure a way to. Tried to see if they unscrew from the front of the dash and also from behind the dash as well.
Any suggestions on how to remove these bulbs for replacement?
Rob_P
Which model and what year?
On my '76 B, there are clips holding them on from the back. The first time i took them out i removed the tach to get a better view.
Rob
Nunyas
you pretty much need to have the hands of a 5y.o. to be able to do anything easily back there. It's not impossible to do stuff with "grown-up" hands, just a little cramped.
W
wigan
Member
Thanks.. I was thinking of that while I tried to locate the stuff the other day. I would be just my luck to pull the wrong wire!
Platinum
A mirror and a flashlight can help.
W
wigan
Member
I posted this problem on another BBS and one fellow thought that something odd was going on as he had never heard of such. The bulbs have not blown, but rather the plastic coloured lense (red/blue). This has happened over a period of a few months. He suggested that the only thing I can figure is that the lights have much too high wattage bulbs in them, or the system voltage is off the scale - whatever, it needs to be found and fixed before replacing them. I suppose that for plastic jewels some alien solvent might do it, but nothing should break glass ones
Carlbanan56 MGB High beam problems MG 4
R Speedo High Beam Warning Light Color Austin Healey 14
A MGA High beam indicator light not working MG 2
77MidgetMkIV High Beam/Turn Signal switch issue? Spridgets 21
D High beam Lamp Spridgets 3
GTP1960 TR2/3/3A High beam indicator malfunction Triumph 3
Tinkerman HIGH BEAM LIGHT Ground Wire Triumph 5
W BE ignition and high beam jewels... Spridgets 12
W BE ignition and high beam jewels... Spridgets 0
wkilleffer Adding relays to the low and high-beam circuits MG 10
Rob Glasgow High Beam Indicator Color - At last the answer Austin Healey 3
drooartz Moving high beam switch Spridgets 13
T High Beam Headlights Jaguar 1
C One High Beam doesn't work Triumph 5
mjobrien High Beam Switch Mounting [Dipper] Austin Healey 7
19_again Blue high beam indicator MG 8
D High Beam Indicator Always On Triumph 9
T High-beam switch Triumph 2
M high beam light cover Spridgets 13
X no beam/ high beam! MG 6
Carlbanan56 MGB High rpm problem MG 27
G High Oil Pressure Austin Healey 2
P TR2/3/3A British High Torque starter Triumph 6
MikeAH100M High Temp Engine Miss Austin Healey 2
Carlbanan56 MGB High resistance MG 2
Gatheringtree TR2/3/3A Faltering at high RPM and under load demand Triumph 34
S TR2/3/3A floundering At High RPM Triumph 29
M High-Torque Starter Austin Healey 10
Martinld123 High-Torque Starter Austin Healey 4
B TR4/4A High Torque Starter Wiring Triumph 9
LAW75 High-Pitched Noise Austin Healey 13
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
Hamish Racing General Tech Petrol/Gas with high ethanol Triumph 3
Taftster MGB Electric Gauges Read High, Any guesses? MG 5
B High-Torque Starter Rattling Noise Austin Healey 3
M 1275 too high? Spridgets 2
dougie Targa High Country 2021 Austin Healey 2
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
J Experience with High Ratio Steering Box? Austin Healey 15
Lin Gear Reduction High-Torque Starters: Inertia or Pre-engaged? Austin Healey 4
M TR6 High Compression in One Cylinder Triumph 28
AUSMHLY 64 front end too high Austin Healey 14
steveg High altitude mixture observations Austin Healey 4
R General Tech High altitude adjustments Triumph 3
R High Altitude adjustments Austin Healey 3
Simmo TR2/3/3A High Oil pressure Triumph 11
D TR5/TR250 High oil pressure Triumph 5
B TR6 1970 High Back Seats for TR6 - Side bolste wires squabs neededr Triumph 3
bfitz TR6 72 TR6 clutch high engagement point Triumph 16
D TR2/3/3A Alternator dial runs high Triumph 5
