One High Beam doesn't work
Colin_D
Member
OK guys, I got the TR6 running again (loose rotor), wipers work, directionals, hazards, low beams but only one high beam.
I swapped the light to make sure it wasn't the just bulb. Has this happened to anyone else?
Cheers,
Colin
T
Tinster
Yup. A poorly installed bullet connector on
one high beam wire.
d
T
Tinster
DNK said:
Nice job Dale :thumbsup:
<span style="color: #000066">Well Don,
even a blind pig will eventually find an acorn in
the forest- if he roots thru enough rotten leaves.
d</span>
Carlbanan56 MGB High beam problems MG 4
R Speedo High Beam Warning Light Color Austin Healey 14
A MGA High beam indicator light not working MG 2
77MidgetMkIV High Beam/Turn Signal switch issue? Spridgets 21
D High beam Lamp Spridgets 3
GTP1960 TR2/3/3A High beam indicator malfunction Triumph 3
Tinkerman HIGH BEAM LIGHT Ground Wire Triumph 5
W BE ignition and high beam jewels... Spridgets 12
W BE ignition and high beam jewels... Spridgets 0
wkilleffer Adding relays to the low and high-beam circuits MG 10
Rob Glasgow High Beam Indicator Color - At last the answer Austin Healey 3
drooartz Moving high beam switch Spridgets 13
T High Beam Headlights Jaguar 1
mjobrien High Beam Switch Mounting [Dipper] Austin Healey 7
19_again Blue high beam indicator MG 8
D High Beam Indicator Always On Triumph 9
W high beam/engine light MG 7
T High-beam switch Triumph 2
M high beam light cover Spridgets 13
X no beam/ high beam! MG 6
Carlbanan56 MGB High rpm problem MG 27
G High Oil Pressure Austin Healey 2
P TR2/3/3A British High Torque starter Triumph 6
MikeAH100M High Temp Engine Miss Austin Healey 2
Carlbanan56 MGB High resistance MG 2
Gatheringtree TR2/3/3A Faltering at high RPM and under load demand Triumph 34
S TR2/3/3A floundering At High RPM Triumph 29
M High-Torque Starter Austin Healey 10
Martinld123 High-Torque Starter Austin Healey 4
B TR4/4A High Torque Starter Wiring Triumph 9
LAW75 High-Pitched Noise Austin Healey 13
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
Hamish Racing General Tech Petrol/Gas with high ethanol Triumph 3
Taftster MGB Electric Gauges Read High, Any guesses? MG 5
B High-Torque Starter Rattling Noise Austin Healey 3
M 1275 too high? Spridgets 2
dougie Targa High Country 2021 Austin Healey 2
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
J Experience with High Ratio Steering Box? Austin Healey 15
Lin Gear Reduction High-Torque Starters: Inertia or Pre-engaged? Austin Healey 4
M TR6 High Compression in One Cylinder Triumph 28
AUSMHLY 64 front end too high Austin Healey 14
steveg High altitude mixture observations Austin Healey 4
R General Tech High altitude adjustments Triumph 3
R High Altitude adjustments Austin Healey 3
Simmo TR2/3/3A High Oil pressure Triumph 11
D TR5/TR250 High oil pressure Triumph 5
B TR6 1970 High Back Seats for TR6 - Side bolste wires squabs neededr Triumph 3
bfitz TR6 72 TR6 clutch high engagement point Triumph 16
D TR2/3/3A Alternator dial runs high Triumph 5
