BE ignition and high beam jewels...
Whitephrog
... are like socks in the mashing machine. They mysteriously disappear. I'm not sure they really ever existed, only a myth.
Last week I installed my NOS tach in my dash when I noticed that there was no jewel in the high beam slot. The tach came straight from an undisturbed Smiths box. I had a few tach and speedometer spares so I went to get a jewel from one of them. None there either!
Is there a source for these jewels? If not, what have others done? I'm considering using red LED bulbs in those slots but would prefer to have the jewels.
dklawson
I believe Jack Laird recommends taking those colored plastic tabs off of office supply notebook dividers and using a hole punch to make disks to use as jewels. I think he just glues them to the back of the gauge face.
As for the LEDs, I don't remember if you have a generator or alternator on the Bugeye. If you have an alternator the charge warning lamp can be an LED but it's a bit more complicated than simple indicator lights as used for oil pressure, turn signal, etc. If you get to that point I'll be happy to elaborate on what's involved.
W
Whitephrog
Using a generator, would the LED work for the high beam and ignition indicator slots?
jlaird
yep, that's what Drew and I did, works fine and you can not tell difference after installed.
jvandyke
I was playing with these just last night. I took apart my tach and speedo to drill another hole to add another bulb for better night lighting. The highbeam warning jewel separated from the back side, I think the faceted jewel part can come off the rest of the "lens" leaving it in the back. There's a white tube thingy that connects the "lens" to the black tube/bulb holder. I painted the inside of this tube silver (better light out the front?). I hope to just carefully glue the jewel face back on. Doesn't help much does it? I'd be looking through my daughter's old dolls and toys looking for a bit of costume jewelry, sometimes get lucky, troll cheap junk toys at the dollar store?
bugimike
Look in craft stores for plastic beads of the right color...they can be melted and formed...I did that for my turn-signal indicator and it worked out pretty well!
W
Whitephrog
Does anyone have a photo of one of these mysterious creature appropriate for a BE?
jvandyke
Great idea. Craft stores have tons of weird things. Am I right that the front part, the jeweled faceted part is connected to the rest of the colored part and not supposed to be separate? I don't have picture but I'll make one a second.
drooartz
The Bugeye ones did not have faceted jewels, just a little red dot. Punch it out of the binder plastic, and then sand it down so it's press fit into the holder. Us the head of a nail to pop it into place. No glue needed.
Nice and simple. I don't have a picture handy, it looks like it should.
jvandyke
Okay, sorry. BE is not the same as MK1 Midget or MK11 Sprite in the warning light area.
K
KSIS
I had the same issue in a 62 VW bug. I used the folder method. The only issue I had was to double it up to make it darker. I was also missing the jewel in my Spitfire. I went to Jo-ann Fabric and found a bag of beads. Wouldnt you know they had the exact jewel I needed I bought a bag of twelve.
I would like to see a pic of what your jewels (the ones in the dash) look like. I found one from a spit and a midget in my parts bin.
Sarastro
I've replaced these a couple of times with plastic "jewels" from a craft supply store. I bought a bag of assorted ones for a few bucks, and found some that were close to fitting. I just sanded off the metal coating on the flat side, epoxied it to a wood stick from a q-tip, which worked as a holder for sanding the edges down to size. Then, broke off the q-tip stick, cleaned it up, and epoxied it in place with clear epoxy. Looks nice, works fine.
tweety
I'm known in my local Micahel's and Joann stores for having the most off beat uses for the things I buy. Now I have a new one
W BE ignition and high beam jewels... Spridgets 0
M ignition coil high tension lead connection Spridgets 10
jmayled High Idle - Electronic Ignition Triumph 12
R Ignition Failure Austin Healey 12
R Bugeye ignition switch Spridgets 2
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
T 100 BN2 Possible Ignition Issue Austin Healey 9
Cokerair TR4/4A Fried Ignition Coil Triumph 18
R Wanted Bugeye ignition switch Spridgets Classified 2
J TR2/3/3A Red ignition light stays on Triumph 7
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
F Hot Ignition Coil Austin Healey 6
J Ignition Key Malfunction Austin Healey 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
SherpaPilot TR6 Ignition Switch Question Triumph 13
PAUL161 T-Series MGTF Ignition Key MG 7
P TR2/3/3A ignition switch smoking Triumph 12
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
W Healey BN1 Ignition Light Austin Healey 8
C TR6 Ignition Switch for 1972 TR6 Triumph 1
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
E Ignition Timing Austin Healey 14
T TR6 Continuous Starting and Ignition Issues Triumph 6
TRickster6 MGB electronic ignition on '73 MGB MG 1
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
jlaird MGB ignition switch MG 2
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
Lin Ignition timing question Spridgets 2
H MGB 1980 mgb no power from ignition switch MG 23
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
M Tachometer not working following ignition upgrade Austin Healey 10
Cappy Ignition Warning Light Austin Healey 6
longbridgehealey Bugeye ignition switch Spridgets 4
J Ignition Key Cylinder Removal Austin Healey 3
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Installation Notes for 1-2-3 Electronic Ignition Austin Healey 1
S Ignition advance weights - how to lube? Austin Healey 5
K TR2/3/3A Ignition Timing? Triumph 11
WJKB-TR6 TR6 '73 Ignition [IGN] Red Light questions. Triumph 6
WJKB-TR6 TR6 Ignition Switch-73TR6 Triumph 5
