Crane or Fast XR700 Electronic Ignition
Lin
I have a few installation questions for anyone who may be experienced and familiar with this optical electronic ignition system. Thank you!
Lin
Lin
Lin
Thanks, John. I was having trouble with adjusting the optical trigger. My unit has worked great, but the little wires coming from the trigger through the side of the distributor have gotten stiff and actually move the trigger even though I have the screw on the swing arm tightened well. Since I figured out the problem I guess I no longer need anything. Thanks for the response!
Lin
John Turney
You might still be able to buy a replacement trigger with new wires. I bought one to use as a speedometer cable turn counter for a tripmeter.
matmire Crane XR700 electronic ignition, now FAST XR700. Spridgets 12
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
PAUL161 T-Series Crane Cam MG 0
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
B Crane Cams Electronic Ingnition Austin Healey 9
RickB MGB Crane Cams XR700 Fireball - wet conditions? MG 7
Marvin Gruber TR5/TR250 Pertronix vs Crane electronic ign Triumph 1
PAUL161 General MG Crane Electronic Ignition MG 9
B Crane XR700 Installation Problem Triumph 16
DNK Crane Ign MG 6
1 MGB-GT Engine hoist/crane boom length? MG 17
PAUL161 Hap, Crane cams? MG 6
bighealeysource Anyone using an Allison or Crane on your Healey Austin Healey 7
dklawson Bad Economy Forces Crane Cams to Shut Down Spridgets 7
dklawson Economy Shuts Down Crane Cams Triumph 5
T lotus excel ignition - can i run a crane hi-6 ? Lotus 0
P Allison/crane xr700 install Triumph 1
S Pertronix Ignition VS Crane/Alisson Ignition? Triumph 7
Z Crane XR700 help needed, car won't run Triumph 27
bmurphy7369 Wiring help needed badly... 1975 XJ6 Crane setup.. Jaguar 8
bmurphy7369 XJ6 SII 1975 with Crane Ignition dies when warm Jaguar 10
tosoutherncars Crane ignition question Spridgets 15
A Crane vs. Pertronix ignition Triumph 9
Z RVI Tach w/ crane ignition? Spridgets 2
T MGB Static timing a MGB w/ a Crane Electronic Ignition MG 5
Atrus Crane/Pertronix Ignition Question Spridgets 11
Sarastro Crane electronic ignition installation Spridgets 3
bravenrace Pertronix or Crane? TVR 8
Michael Oritt Crane XR3000 ignition system Racing 4
F Re: crane xr 700 optic ignition system question MG 10
V TR6 TR6 Crane Cam Grind# S-264-C Triumph 2
L Spark Plugs with Crane Ignition MG 10
A Help with electronic ignition [Crane] MG 11
R Crane Cams Electronic Ignition Module Austin Healey 5
K Crane Cam Spridgets 4
C Pertronix versus Crane ignition kits ? MG 7
Y Crane Vs Pertronix Austin Healey 5
G Pertronix vs Crane Ignition MG 18
Hamish Racing TR2/3/3A Fast and wet TR3a Triumph 0
B Bugeye Original Engine Compartment Sheet Metal. Act Fast! Spridgets Classified 0
Hamish Racing TR2/3/3A Fast Road TR3a on figure of 8 sprint track - UK Triumph 10
B AH Spares Fast-Flow Fuel Manifold Austin Healey 2
T TR2/3/3A Turn Signals Blinking too fast Triumph 2
T TR2/3/3A What causes fast flashing turn signals when all bulbs & indicator light are flashing? Triumph 15
HalLucy Post-War Other Renown - Idle too fast Triumph 5
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
P Fast Healey at Lime Rock. Austin Healey 2
wkilleffer MGB Air leaks and fast idle speed MG 11
HealeyPassion AH Spares Fast Flow Manifold.... Austin Healey 32
T TR2/3/3A 1/4 mile fast time driving technique Triumph 15
