TR2/3/3A Turn Signals Blinking too fast
tedwone
I'm helping a friend get all of the lights working on his 59 TR3A after someone did some "creative rewiring". I have managed to get all the lights to work, but the left turn signal lights, both front and rear are blinking at a much faster rate than the right side. Both lights blink. I know that the grounding can affect the blink rate, but will this occur if only one of the left turn signal lamps has a faulty ground? What other things can cause only the left signals to blink too fast? Can incorrect bulbs cause this problem?
smaceng
Yes, incorrect bulbs can do this. Note that when just one blinker bulb is burned out, the lights blink faster. This is due to less resistance in that circuit. What could cause a decreased resistance, but still have the lights work? Could be incorrect bulbs of a lower resistance. Try switching both bulbs side to side. Good luck, Scott in CA
TR3driver
Great Pumpkin - R.I.P
Having the wires switched on the front lamp can do it, too. Check that the turn signal is much brighter than the park lamp function.
KVH TR4/4A Rear Turn Signals are Blinking In Reverse Triumph 2
Carlbanan56 MGB Mgb turn signals MG 17
K 68 midget. No horn, headlights, turn signals Spridgets 9
J MGB help, turn signals do not work MG 3
bighealeysource Turn Signals Austin Healey 21
doakley Spitfire Turn Signals Triumph 3
BierRunner TR6 Turn Signals/Hazards don't work Triumph 16
Got_All_4 TR5/TR250 Lost Turn Signals Triumph 2
BoyRacer LED Turn Signals Austin Healey 5
E MGB Turn signals 65 mgb MG 4
W MGB Turn signals on 78 MGB MG 3
jfarris TR2/3/3A Modified turn signals/brake lights on a 56 Triumph 6
D MGA MGA turn signals MG 3
T TR2/3/3A What causes fast flashing turn signals when all bulbs & indicator light are flashing? Triumph 15
R BT7 turn signals Austin Healey 5
Martinld123 Brake Lights But No Turn Signals Austin Healey 9
Joe Schlosser LED Turn signals Austin Healey 9
Jim_Gruber BE Quiz for Today - Beehive front Turn Signals take a ? possibly 6/32 screw Spridgets 1
Jim_Gruber BE Quiz for Today - Beehive front Turn Signals take a ? possibly 6/32 screw Spridgets 2
Joe Schlosser BugEye turn signals Spridgets 5
vickxxx T-Series turn signals for MGTD MG 5
jfarris TR2/3/3A Front Turn Signals / Marker lights Triumph 3
Jim_Gruber Turn Signals and Flasher Lamp on Dash Spridgets 8
G BJ8 Phase II conversion to LED turn signals Austin Healey 11
A When were turn signals original equipment on Mk1 Bugeye Sprites? Spridgets 4
L TR6 No power/not enough power to turn signals, wipers Triumph 8
Crankshaft TR2/3/3A Loss of power to wipers ad turn signals? Triumph 11
J TR2/3/3A Add brake light to Rear turn signals Triumph 12
RJS TR4/4A Electrical Question - brake lights, fuel/gas gauges, turn signals failed Triumph 9
J MGB Electrical issue- turn signals dim and cause the brake warning light to flash MG 8
5 TR2/3/3A LED bulbs w/turn signals problem Triumph 4
bobh Faster Turn Signals Triumph 2
Morris A lesson in turn signals... Spridgets 4
I No turn signals Triumph 17
B oh curmbs! turn signals and brake lights were... MG 14
B Turn Signals Austin Healey 2
HealeyRick Turn Signals Not Working Austin Healey 6
Jim_Gruber Turn Signals have stopped working Spridgets 25
Anthony_S Turn signals and indicator light Triumph 11
coj Electrical system - turn signals - green light Austin Healey 1
apbos Speedwell Bonnet turn signals Spridgets 13
stretchit2 Turn Signals , Brake Lights, Off Switch - Yikes Austin Healey 1
N Please help! turn signals. Spridgets 20
N Turn signals on the "blink" Triumph 4
King_of_England Clubman turn signals British Motor Corp 1
Brooklands TR2/3/3A Front Turn Signals on TR3B grill Triumph 7
spnx amber SP250 turn signals Other British Cars 5
Bruce_B Flasher and Turn Signals - Wiring on BE Spridgets 2
Jim_Gruber Turn Signals - Not working / Troubleshooting Spridgets 6
