T-Series turn signals for MGTD
vickxxx
I'm looking to install turn signals on a 1952 MGTD barn find find that I recently acquired. I've seen headlamps that have LED indicator lighting mounted in them and am wondering if anyone out there has /is using these in their TD. I'm trying to avoid the option of mounting indicators on the fenders. Thanx!
Jim B.
Member
I also have an 52 MG-TD.
You can easily change the existing front fender side lamps from a single contact socket to a double contact socket. This will allow flashers on the front without the need for LED lamps. That contact set is available form Abingdon Spares. Part 37-030 $29.95 or Moss 152-600 $26.30 (on sale)
Getting them to flash is another issue.
There is a LUCAS module available. In essence it removes power from the break lights on the side you want to flash and provides flashing power to both the stop lamp filament and the (new) flashing filament on the front fender sidelamps. From Moss its 141-400 $110. You will also need the special time delay switch to flash the lights Moss again 162-400 at $138 and the lever, 150-6-- $8 and the mounting bracket which is an additional $6.
This is the easiest rout to go through a bit expensive. Abingdon has similar items. I did get my time delay switch from the UK even with shipping it was less expensive.
When I rebuilt my TD I used a wiring harness that would accommodate the flashers. If your TD does not have this harness you will need to add a few wires.
If you look at the diagrams in the WSM you will see what additional wiring is needed.
Another route to go is to add a period add-on stalk switch and a set of rear flasher lamps.
That approach is explained here:
[SIZE=-1]https://ttypes.org/ttt2/indicators-for-a-mg-td
This is not "Original" but less expensive and probably better.
In either approach you can get LED lamps that are brighter and functionally fit in the sockets.
A word of caution. If you have positive ground your LED's must be designed for that. They are not universal.
[/SIZE]
Sarastro
For the turn-signal switch in my TD, I just installed a toggle switch in place of the rheostat for the dash lamps. That rheostat didn't strike me as something that was very useful. Not original, of course, but also not a very noticeable modification.
I also made my own relay box and renovated the lamps with off-the-shelf bulb fixtures.
You don't need to follow the expensive route; a little resourcefulness goes a long way.
https://www.nonlintec.com/mgtd/electrics/
Hahaha.
vickxxx
vickxxx
Thanx Steve. A little resourcefulness does go a long way, especially here in Hawaii. The reason I'm needing turn signals is to pass the safety inspection here in Hawaii. Toggle switch is the easiest and cleanest way to go. I found a pair of indicators(for Harley Davidson, filament) for the front that are small and shaped like the headlamp buckets. I'll be using a 3 wire trailer light converter to wire this all in. I found this article https://www.how-to-build-hotrods.com/turn-signals.html . Seems to be pretty straightforward and I can use the tail/brake lights for the rear indicators.
vickxxx
vickxxx
Using the trailer converter will only work on negative ground systems (sigh). In my case I'll be using separate tail light indicators.
Carlbanan56 MGB Mgb turn signals MG 17
K 68 midget. No horn, headlights, turn signals Spridgets 9
J MGB help, turn signals do not work MG 3
bighealeysource Turn Signals Austin Healey 21
doakley Spitfire Turn Signals Triumph 3
BierRunner TR6 Turn Signals/Hazards don't work Triumph 16
Got_All_4 TR5/TR250 Lost Turn Signals Triumph 2
BoyRacer LED Turn Signals Austin Healey 5
E MGB Turn signals 65 mgb MG 4
W MGB Turn signals on 78 MGB MG 3
jfarris TR2/3/3A Modified turn signals/brake lights on a 56 Triumph 6
T TR2/3/3A Turn Signals Blinking too fast Triumph 2
D MGA MGA turn signals MG 3
T TR2/3/3A What causes fast flashing turn signals when all bulbs & indicator light are flashing? Triumph 15
R BT7 turn signals Austin Healey 5
KVH TR4/4A Rear Turn Signals are Blinking In Reverse Triumph 2
Martinld123 Brake Lights But No Turn Signals Austin Healey 9
Joe Schlosser LED Turn signals Austin Healey 9
Jim_Gruber BE Quiz for Today - Beehive front Turn Signals take a ? possibly 6/32 screw Spridgets 1
Jim_Gruber BE Quiz for Today - Beehive front Turn Signals take a ? possibly 6/32 screw Spridgets 2
Joe Schlosser BugEye turn signals Spridgets 5
jfarris TR2/3/3A Front Turn Signals / Marker lights Triumph 3
Jim_Gruber Turn Signals and Flasher Lamp on Dash Spridgets 8
G BJ8 Phase II conversion to LED turn signals Austin Healey 11
A When were turn signals original equipment on Mk1 Bugeye Sprites? Spridgets 4
L TR6 No power/not enough power to turn signals, wipers Triumph 8
Crankshaft TR2/3/3A Loss of power to wipers ad turn signals? Triumph 11
J TR2/3/3A Add brake light to Rear turn signals Triumph 12
RJS TR4/4A Electrical Question - brake lights, fuel/gas gauges, turn signals failed Triumph 9
J MGB Electrical issue- turn signals dim and cause the brake warning light to flash MG 8
5 TR2/3/3A LED bulbs w/turn signals problem Triumph 4
bobh Faster Turn Signals Triumph 2
Morris A lesson in turn signals... Spridgets 4
I No turn signals Triumph 17
B oh curmbs! turn signals and brake lights were... MG 14
B Turn Signals Austin Healey 2
HealeyRick Turn Signals Not Working Austin Healey 6
Jim_Gruber Turn Signals have stopped working Spridgets 25
Anthony_S Turn signals and indicator light Triumph 11
coj Electrical system - turn signals - green light Austin Healey 1
apbos Speedwell Bonnet turn signals Spridgets 13
stretchit2 Turn Signals , Brake Lights, Off Switch - Yikes Austin Healey 1
N Please help! turn signals. Spridgets 20
N Turn signals on the "blink" Triumph 4
King_of_England Clubman turn signals British Motor Corp 1
Brooklands TR2/3/3A Front Turn Signals on TR3B grill Triumph 7
spnx amber SP250 turn signals Other British Cars 5
Bruce_B Flasher and Turn Signals - Wiring on BE Spridgets 2
Jim_Gruber Turn Signals - Not working / Troubleshooting Spridgets 6
