Electrical system - turn signals - green light
coj
Member
My 1960 3000 is a rebuild done around 1990. The electrical system(IE lights, blinkers,starter, key switch all appear to be wrapped together in the same cloth covering from an original.Recently my turn signals stopped working.The box that "Clicks" makes it's noise when you manually move the the turn lever from side to side. The green light turn signal indicator now has a habit of staying lit all the time,even in the neutral position, until I "Jiggle" some wires around behind the dash. I can see the wires that go to the indicator.When I hit a bump it comes on again. disconecting the green indicator does not have any effect on making the flashers work, unless I manualy just move the lever back and forth. Anyone have any ideas. I do not want to replace the flasher box if it not related to the green indicator light staying on and if " jiggling" the wires or turning off the light completly still does not allow the flashers to work.
There are so many possibilities here; the fact that "things happen" when going over bumps and jiggling YELL loose connections and/or grounded wires.
Get out the manual, and start tracing everything out, each circuit from start to finish.
Or, you could wait until the harness goes up in smoke. It's real easy to find the trouble spot then.
Edit: A common place for things to go awry, is where the wiring exits the stator tube, at the leading edge of the steering box (the wiring running down the center of the steering column).
Yes, I've got a picture...
CARSINC Sprite Electrical System Information Spridgets 2
C Ghost in the electrical system Austin Healey 51
R TR2/3/3A Early TR3 electrical system Triumph 12
6 Electrical System Issue- Thougths Please Spridgets 6
Lbp TR2/3/3A What Might Cause The Entire Electrical System on my TR3A to Die? Triumph 19
Sarastro Not your grandmother's Bugeye electrical system Spridgets 8
kyreb1862 Electrical System Problem Need Help ASAP MG 7
C Electrical system fun! MG 5
T TR6 Fry a TR6 electrical system in these easy steps Triumph 16
A Electrical System Triumph 1
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
N MGB Electrical Part Identification MG 3
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
SNClocks Electrical Wire Lug Spridgets 2
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
F General TR Electrical parts Triumph 6
S TR2/3/3A Electrical Triumph 31
lram59 General Tech Electrical terminals Triumph 8
6 Electrical Help Please Spridgets 7
B Bugeye Electrical Diagram with additions Spridgets 6
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
KVH General Tech O/D Electrical Wire Burned Triumph 22
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
E GT6 Help electrical guru needed Triumph 4
B Bugeye Electrical Diagram Spridgets 0
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
D TR2/3/3A TR3A electrical issues Triumph 2
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 17
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
Simmo General Tech Electrical question Triumph 4
B BJ8 Phase 1 Electrical Diagram Austin Healey 21
T TR6 72 TR6 electrical snafu Triumph 4
P TR6 Electrical Problem Triumph 26
M Difficult Electrical Problem in 59 BE with Generator Spridgets 6
N Electrical Issues Need Help Austin Healey 8
H Re: electrical short wiring damage Spridgets 11
I Bugeye electrical questions Spridgets 17
N Electrical Troubleshooting Advice Needed Spridgets 6
steveg Electrical sleeving Austin Healey 11
N TR6 Electrical Issues Triumph 5
N Electrical issue. FORUM Navigation Questions 2
S TR2/3/3A Electrical Issue Triumph 40
KVH General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch Triumph 3
6inline Electrical gremlins giving me fits Austin Healey 18
DornTRoriginal TR2/3/3A Electrical Wiring Best Practices Triumph 13
