Electrical System Issue- Thougths Please
60Bugeyefan
Today I attempted to replace plugs, points and coil for my 60 Bugeye following the Hayes manual and John Twist videos. After completing the work I have a serious electical issue that I inadvertantly created. When I turn on the ignition I get nothing. No fuel pump, no lights, nothing on the dash volt meter not even horn works. I have attempted to trouble shoot by taking the following measures:
1. Checked battery. No issue 12.6V using wave meter.
2. Checked fuses no issue but to be sure, replaced both.
3. Checked wiring on the coil, put old coil back in.- no change.
4. Checked breaker gap and correct position of fiber washer- they are correct.
I assume I may have created a grounding issue but can not figure out how I did this by working on the distributor or coil. Has anyone else experienced this kind of failure?
Gliderman8
Sorry, I have to ask.... did you disconnect the battery terminals prior to working on the car.... I know, I know, but I had to ask the obvious.
60Bugeyefan
Hi Elliot
Yes, I disconnected the battery via a terminal switch. When I completed the work on the ignition, i reconnected the battery. I think Rick may on the right track. Since everything is electrically dead on the car, I think it points to a failure point close to or at the battery. I will recheck the battery posts in the morning as well as the ground strap which I have not checked. Worst case I will get out the wiring diagram and starting at the battery work my way to the key components looking for a fault unless there is a more effecient way that I am overlooking.
John
Gliderman8
John- You also might check the terminal switch that you used to disconnect the battery... check to make sure you have +12v coming out of the switch.
With everything dead electrically, it has to be easy to find.
JPSmit
Check your connections to the starter solenoid, you might have reinstalled a wire on the wrong side. It would give exactly those symptoms, don't ask me how I know. :D
60Bugeyefan
All-
Thanks for the input. This morning I started at the battery with the meter. PO had installed a dash ammeter and the lead from the battery had come off the post with the brass nut laying conveniently on the floor. Put the lead on the post and retightened the nut and the car fired right up. Murphy's Law is alive and well but better for this to occur in the driveway rather than on the open road.
John
CARSINC Sprite Electrical System Information Spridgets 2
C Ghost in the electrical system Austin Healey 51
R TR2/3/3A Early TR3 electrical system Triumph 12
Lbp TR2/3/3A What Might Cause The Entire Electrical System on my TR3A to Die? Triumph 19
coj Electrical system - turn signals - green light Austin Healey 1
Sarastro Not your grandmother's Bugeye electrical system Spridgets 8
kyreb1862 Electrical System Problem Need Help ASAP MG 7
C Electrical system fun! MG 5
T TR6 Fry a TR6 electrical system in these easy steps Triumph 16
A Electrical System Triumph 1
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
N MGB Electrical Part Identification MG 3
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
SNClocks Electrical Wire Lug Spridgets 2
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
F General TR Electrical parts Triumph 6
S TR2/3/3A Electrical Triumph 31
lram59 General Tech Electrical terminals Triumph 8
6 Electrical Help Please Spridgets 7
B Bugeye Electrical Diagram with additions Spridgets 6
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
KVH General Tech O/D Electrical Wire Burned Triumph 22
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
E GT6 Help electrical guru needed Triumph 4
B Bugeye Electrical Diagram Spridgets 0
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
D TR2/3/3A TR3A electrical issues Triumph 2
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 17
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
Simmo General Tech Electrical question Triumph 4
B BJ8 Phase 1 Electrical Diagram Austin Healey 21
T TR6 72 TR6 electrical snafu Triumph 4
P TR6 Electrical Problem Triumph 26
M Difficult Electrical Problem in 59 BE with Generator Spridgets 6
N Electrical Issues Need Help Austin Healey 8
H Re: electrical short wiring damage Spridgets 11
I Bugeye electrical questions Spridgets 17
N Electrical Troubleshooting Advice Needed Spridgets 6
steveg Electrical sleeving Austin Healey 11
N TR6 Electrical Issues Triumph 5
N Electrical issue. FORUM Navigation Questions 2
S TR2/3/3A Electrical Issue Triumph 40
KVH General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch Triumph 3
6inline Electrical gremlins giving me fits Austin Healey 18
DornTRoriginal TR2/3/3A Electrical Wiring Best Practices Triumph 13
