TR6 Electrical Issues
NormLewis
As I just got this car I am new to the intracacies of the electrical system. When I first started I had lights, signals, horn etc... I proceeded to turn the engine over and heard a pop sound in the engine compartment and now have no lights, signals, horn or spark. The engine turns over fine, no fuses are blown so I am at a loss where to look next. Any help would be greatly appreciated.
poolboy
You need to state the year because of differences but on the battery positive cable see if there's a junction where certain brown wires interconnect with the positive battery cable...check there.
Sarastro
We can speculate all day about the problem, but this is a good opportunity to learn basic troubleshooting. Start at the battery, trace through the circuit, and find out where you are losing power. You will need a wiring diagram, for sure.
You can eliminate large parts of the electrical system just from the behavior of the problem; for example, if all the electrics are dead, there's a limited area where the problem could be. The idea is simply to use a logical process of eliminating things that could be the problem until you narrow in on it.
D TR2/3/3A TR3A electrical issues Triumph 2
N Electrical Issues Need Help Austin Healey 8
I TR6 Electrical issues - please help. Triumph 5
pkmh BJ8 stalling out to due electrical issues Austin Healey 50
robdmau Electrical Issues... Spridgets 4
JodyFKerr Wedge Electrical issues [TR8] Triumph 67
Jim_Gruber Still fighting Fuel vs. Electrical issues Spridgets 12
T Still having issues with the electrical MG 5
R TR2/3/3A Intermitant electrical issues TR3A Triumph 3
vping Electrical issues worked out. MG 15
F Various Electrical Questions and Issues MG 11
W Ignition/ electrical issues? Spridgets 3
CARSINC Sprite Electrical System Information Spridgets 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
N MGB Electrical Part Identification MG 3
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
SNClocks Electrical Wire Lug Spridgets 2
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
F General TR Electrical parts Triumph 6
S TR2/3/3A Electrical Triumph 31
lram59 General Tech Electrical terminals Triumph 8
6 Electrical Help Please Spridgets 7
B Bugeye Electrical Diagram with additions Spridgets 6
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
KVH General Tech O/D Electrical Wire Burned Triumph 22
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
E GT6 Help electrical guru needed Triumph 4
B Bugeye Electrical Diagram Spridgets 0
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 17
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
Simmo General Tech Electrical question Triumph 4
B BJ8 Phase 1 Electrical Diagram Austin Healey 21
T TR6 72 TR6 electrical snafu Triumph 4
P TR6 Electrical Problem Triumph 26
M Difficult Electrical Problem in 59 BE with Generator Spridgets 6
H Re: electrical short wiring damage Spridgets 11
I Bugeye electrical questions Spridgets 17
N Electrical Troubleshooting Advice Needed Spridgets 6
steveg Electrical sleeving Austin Healey 11
N Electrical issue. FORUM Navigation Questions 2
C Ghost in the electrical system Austin Healey 51
S TR2/3/3A Electrical Issue Triumph 40
KVH General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch Triumph 3
6inline Electrical gremlins giving me fits Austin Healey 18
