Are you sure the corner lamps don't flash when you turn on the turn signals? Does the fuel gauge still work?
If it is just the wipers and the indicator for the turn signals (and possibly the fuel gauge isn't accurate), then I would suspect that you've knocked loose the ground wire from the panel. There is a tie point with a screw on the back, which is supposed to have a wire running from it through the harness out to the control box
But if the corner lamps and fuel gauge don't work, then I'd look at the wires around the ignition switch. There should be a separate white wire from the switch that runs through the harness out to the fuse block. With the key on, it supplies power to the main fuse, which in turn supplies the wiper motor, turn signals, fuel gauge (brake lights and heater).
In fact, since it is much easier to get to, I would probably start by checking the voltages at that fuse, with the key and wiper switch on. Then I'd check over at the wiper motor (which again is a lot easier to get to). If nothing else, that will give you more information about what the problem might be under the dash.
