moremonkey
For the past several years I've had a recurring issue with my BN1 that only happens when running in third gear with RPM over 3,000. Because I generally don't find myself in that situation, I ignored the problem. But when the overdrive stopped working reliably last summer (just fixed), it became more of an issue.
Anyway, now that I am working my way through winter repairs, I thought I would see what the collective wisdom of the Forum has to say about this.
As I said, when the engine runs above 3,000 RPM for any sustained period, the engine will abruptly lose power and sound as if it fouled a plug. The car will struggle and fail to maintain its speed, even with WOT, make kind of a sick burrrrblllll from the tailpipe, and feel like it is running on less than all four cylinders. If I put the clutch pedal in and let the engine drop to idle speed for a few seconds and then blip the throttle, the problem cures itself and won't come back unless I take the RPM back up over 3,000 again under load.
Other than this specific situation, the car runs great.
Any ideas what's going on and how to fix it?
