I just picked up a lovely TR6 and I am getting it ready for the road. It's going to take a bit of money to get it through inspection, but it will be a fine car when I've finished with it. I'm a car nut, usually driving a TVR, but I thought I'd try this Triumph experience for a while...
I have an electrical gremlin that I can't figure out: The wipers and turn signals do nothing.
I have 12V at the wiper motor and flasher unit at the appropriate times, I have continuity to ground at the wiper motor connector. The fuse is new, contacts cleaned in fuse box. The hazards work fine, if a little slowly. In general, the power seems weak to lights and other working circuits such as the blower. I've scoured the car for grounds and cleaned them up where I can find them. The negative from the battery to the block is present, but the battery to body wire is missing so I added a jumper to see if that helped and it did nothing.
The voltmeter shows ~13V when running, the battery is ~12V not running. I think I'm missing a ground location (the car has been repainted and I don't think it's been used since), or the white wires going to the fuse box may have been strained and damaged internally. This is a dry state (AZ) car, so most things are in very good shape and I don't suspect corrosion to be a big issue.
I appreciate any suggestions that you guys may have.
David (in Durham, NC)
