BJ8 losing power and enguine dies
AH67
Been driving the BJ8 and has been fine. This weekend while out for a drive and after a stop, the she did not fire up right away as usual. I did not make much of it. Further down the road, I can feel the car losing power slowly as if she was choking. The accelerator did not do much good and would not rev up. Engine eventually died and the car came down to a stop. I restarted the car and barley made it home. Next day I took it out and she drove just fine.
I thoughts were fuel pump issues but not sure at this point. The pump clicks twice upon a cold start and that is it.
Thoughts ideas?
drambuie
Well, check the easy things first! Disconnect the fuel line and see if there is good unrestricted fuel flow, could be a clogged fuel filter. Check the point gap and condtion of the points, I had a situation like your describing and found it was a bad set of points even though they only had 500 miles on them. Many of the tuneup parts are cheap garbage you get these days including, caps, rotors, coils, condensers and so on. Sounds like a simple problem to me, but sometimes even tracking and process of elimination can be very frustrating. Don't overthink it and just check the easy things for now, also check if you are getting a healthy spark at the plugs so you can separate electrical/ fuel issues. Check Loose wires and so on.
AH67
AH67
thanks so much. I will check both. A fact to consider is that the car has gone through a nut & bolt resto in 08
drambuie
Just because your particular Healey has undergone a nut and bolt restoration does not exempt it from the little nagging things that could go wrong such as defective tuneup parts or other items such as new fuel pumps. Even the most expensive exotics need some bugs exterminated. As I was saying in my first post, most likely a very simple issue. Just a matter of intelligently going about the process of elimination and testing separate systems. In this case, most likely fuel/electric systems. Do you still have the original points ignition set up? Or converted to electronic ignition?
drambuie
Your most welcome, please keep us posted on what you find! That electronc ignition is jumping out at me because of past reviews good and bad! I'm sure their are folks in this forum that can help you trouble shoot it in detail if that is found to be the problem. Take care!
AH67
AH67
the verdict is in and wanted to share the fix and thank you all.
It was a cracked distributor cap after all and you y'all have suggested. Back on the road and thanks again..
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
B BJ8 Centre Console Chrome Strips Austin Healey 5
B Wanted Chrome strips centre console BJ8 Austin Healey Classifieds 0
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
6 BJ8 Headlamp Wiring Austin Healey 1
