BT7 brales poor stopping power - any advice?
fishyboy
Hi all,
I've owned my 1961 BT7 for 25 years. Currently the brakes do not appear to works as well as they have in the past. The peddle has some travel and then has a firmish response. Pumping the brakes does not produce a higher or firmer peddle. When applied the brakes don't exactly bring the car to a shuddering halt, but are slow and progressive. In the past I am sure that the brakes had more stopping power.
The Master Cylinder is newish and the reservoir is only a year old. I have replaced the pads and shoes this week. I have bled and adjusted the rear brakes, but not bled the from calipers.
My thoughts are:-
1) Is there still air in the system? Could air be trapped at the highest point in the system where the pipe enters the MC? I have tried pumping the peddle and loosening the brake pipe nut but only fluid comes out.
2) Could there be a problem with the MC? How can I test the system to try and isolate where the problem might be?
3) Have the brakes always been inefficient and I am somehow remembering them being better than they were?
Any advice welcome.
Phil
Healey Nut
How old are the brake hoses ?
Michael Oritt
Front brakes do the majority of the stopping so you should certainly bleed them as well, but if there were air I doubt you would have the firm pedal you describe.
Perhaps there is some problem with reassembly that is preventing either the fronts or rears or both from fully activating?
You may also have a collapsed hydraulic hose somewhere in the system.
F
fishyboy
Thanks for the replies.
All three hoses have been replaced with steel braided ones in the last 12 months.
I shall try to bleed the fronts today.
Phil
EV2239
If you have a firm pedal and it doesn't pump up much, you probably don't have air in the system. Did the change in brake efficiency coincide with the arrival of new pads and are the rears working properly? There's quite a bias to the rears on a Healey, so if they have stuck pistons (common fault) or whatever, it might account for what you're experiencing.
Pistons can can also stick in the calipers so try locking the wheels to see if wheels are locking prematurely.
F
fishyboy
Hi all
The brakes were poor before I changed the pads and shoes.
EV2239
What do you mean by "locking the wheels to see if wheels are locking prematurely"? If I hit the brakes as hard as I can I cannot lock the wheels when out driving (I certainly could in the past). I don't think the pistons are sticking (the front of the car dips on breaking which suggests the fronts calipers are working). I'll try to check the check the rears by removing the wheels and hubs and applying the brakes.
Phil
Michael Oritt
Phil--
In your first post you said that the brakes do not seem to work as well as they did in the past but in your last you said they did not work well before you changed pads and shoes. Without getting into symantics perhaps this indicates that the problem lies elsewhere in the system such as cylinder sizes, type of fluid, etc. Have you changed any of the components and inadvertently gone to different diameter cylinders? Are you using a different type of fluid? Is it possible there is some problem with the pedal itself?
F
fishyboy
Hi all,
The brakes have been poor for the last couple of years. They are good enough to pass the UK MOT, but do not feel as good as they could be to me. Since the decline I have been slowly working my way through the system, replacing elements until I have reached today where I am at a loss where to go next (I shall bleed the front caliper when time permits). This is what I have done so far.
August 2015
Fitted new Brake MC, new Dual reservoir and three steel brake hoses with no noticeable improvement
June 2016
Fitted new rear brake shoes and front Pads, followed by bleeding and adjusting the rear brakes - again with no noticeable improvement
Phil
red57
Phil,
You should definitely be able to lock the wheels up when driving. I believe in renewing the entire hydraulic system at one time - you haven't said how long it has been since the entire system was rebuilt. You have done the master and flex lines so if you rebuild/replace the front calipers and rear wheel cylinders you will have a fresh hydraulic system to go with the new pads and shoes. At the very least it will give you more confidence knowing all is renewed.
From your description I'd bet on sticky front caliper pistons (the fronts do 60% or more of the braking) but it's just speculation until you open them up and see what condition they are in.
F
fishyboy
Thanks red57,
I like the idea of rebuilding the front calipers, but is probably beyond my capabilities. What is the best way to find out if there is a problem with the calipers before booking it into a garage/shop. Is there something I can check with the wheels off?
Phil
red57
Phil,
You can look for any signs of brake fluid leakage. You can also look to see if the rubber dust excluders (outer seals around the pistons) are cracked/torn or damaged in any way - if these seals are damaged, it can allow grit to enter the bores and cause the pistons to not move freely. But it is also possible that there is corrosion inside the bores that will not be visible until disassembly, but would also result in grit possibly impeding the free movement of the pistons. You haven't mentioned, but if the brakes pull to either side, that is also a possible indication of a sticky piston - eg, if it pulls to the right, look to a possibly sticky piston on the left side. Upshot is more than likely you will need to disassemble to know for sure.
Side note - the original pistons are steel with chrome plating and this plating can fail and allow the steel pistons to rust (most brake fluid is hydroscopic and attracts moisture). I recommend when rebuilding that you replace the pistons with stainless steel ones. Two advantages to SS pistons are, no more rust possible in future and less heat transfer to the brake fluid, extending the life of the fluid (this last part is just my opinion).
Dave
Michael Oritt
This might not be the most economical way to solve the problem but I wish I had a dollar for every time I have thought I solved a problem by replacing one component of a system only to find that another piece was also part of the issue. All of the moisture, dirt, rust, rubber bits and other detritus that has lived within your brake and clutch systems (remember, they share a common reservoir) have--potentially--contaminated and compromised every component, fitting and connecting hose.
steveg
Hi all,
August 2015
June 2016
Phil
Assuming you meant braided stainless flex hoses.
So the only things remaining are: rebuild calipers with new pistons and seals; rebuild rear slave cylinders; bleed all 4 wheels in this order: LR, RR, LF, RF.
I like sealing the bleeder screw threads with teflon tape & using a syringe to pull out the fluid through each bleeder.
One of the posters here suggested tightening the rear brake shoes as tight as you can get them for bleeding, then loosening for operation.
Lotuswins
Phil,
Since you just replaced pads and shoes, I would suspect the pads/shoes aren't bedded in just yet. Did you follow the instructions for bedding the pads? Usually it includes several hard stops from 30mph, and then 60mph until the pads are very hot, then allow to cool and you're good to go. On the rear shoes, since no one arcs the shoes anymore due to asbestos dust fears (which no one uses that anymore), the rear shoes probably have a small contact patch and need time to bed in. You can check the rear shoes to see exactly how much is in contact to verify this theory.
On a side note, the stock pads often offered by the usual suspects don't have a great friction factor. If you dig down into the detail of the pad, via the manufacturers website, you can usually find a friction factor to compare with other manufacturers. I've had good luck with EBC green pads on street vehicles if you decide to lesson pedal pressure at a minimal cost.
This all assumes that the car isn't pulling to any one side, no one wheel is locking up, etc. which implies mechanical malfunctions.
Also, is the MC you replaced the same bore size as specified in the manual??
F
fishyboy
Hi all,
Thanks for all the advice. I think the calipers might be the root of the problem and will check them out.
The new pads and shoes were bedded in. The new ones were the "Couinty" brand. Ill take a look at the EBC ones next time.
Phil
Brinkerhoff
More than likely if the calipers need rebuilding so do the rear wheel cylinders as has been said. The calipers will usually not release well if they are bad but the rear wheel cylinders will cause the brake pedal to be hard when they are frozen.
F
fishyboy
Hi all,
Ive ordered a pair of restored exchange calipers and new rear wheel cylinders which will be fitted at the end of this week. I shall let you know what happens!
Phil
F
fishyboy
Hi all,
Got my local garage to install rebuilt exchange front calipers on my BT7. As the rear brake cylinders were fine they were left.
Big improvement in the brakes. firm peddle with no sponginess, but with a lot of travel. Front wheels now lock under Hard braking.
However, only leaves skid marks on the road from the right-hand front tyres.
Any ideas as to why this may be? Also why is there so much travel on the brake peddle before it firms up?
Phil
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
J BT7 Hardtop Crosspiece Wanted Austin Healey 5
M Wanted WANTED: Hardtop (Factory) for BT7 Austin Healey Classifieds 6
kodpkd 1961 BT7 engine oil Austin Healey 31
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
D Healey 3000 BT7 rear panels Austin Healey 0
D Gearbox Dipstick (BT7) Austin Healey 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
D Rear Seat Side Panels, BT7 Austin Healey 3
F BT7 Stalling Austin Healey 9
apbos BT7 Hardtop For Sale Austin Healey 0
D BT7 Grille Attachment Austin Healey 11
D BT7 Choke Assembly Austin Healey 18
D BT7 Rear Side Panels Austin Healey 0
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
Healey Nut BT7 Windscreen Pillars Austin Healey 4
Fanch00 My 1960 BT7 History Search Austin Healey 1
Healey Nut BT7 Parts Identification Austin Healey 3
MadRiver BT7 Wiring Diagram Austin Healey 4
Healey Nut BT7 Panhard Rod Austin Healey 28
Healey Nut BT7 Rear Suspension Austin Healey 15
J Attaching BT7 Dash Facia Panel Austin Healey 2
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
R 3-point seat belts on late production BT7 MKII Austin Healey 7
T BT7 throttle relay levers short and long Austin Healey 2
C 1960 BT7 Thoughts Austin Healey 14
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
Lin Tach drive housing for BT7 Austin Healey 4
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
T BT7 Hardtop Restoration Austin Healey 6
dougie BT7 Video Austin Healey 8
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
B BT7 Door Seal Installation Austin Healey 13
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
B BT7 Grille surround Austin Healey 9
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
R BT7 Carb floats Austin Healey 1
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
Healey Nut For Sale BJ8 and BT7 parts for sale Austin Healey Classifieds 62
CLB62 1962 Austin Healey BT7 Mk II Austin Healey 15
F Heater pipe and air duct routing BT7 Austin Healey 3
BoyRacer Tips on gluing new fabric to dash on my BT7 Austin Healey 10
F Help need reinstating my heater - BT7 Austin Healey 7
