Power steering
buicfrank
Has anyone installed power steering in a Nash Metropolitan? And how did you do it? Stock 59 no modifications except alternator. Thank Frank
JPSmit
Interesting question - not many here have Mets so we are likely as intrigued as you.
I did a bit of googling and it seems like the steering boxes wear out - can it be refurbed or swapped to rack & pinion? (they aren't that big a car that I would think they would need Power steering - but what do I know :smile: )
I follow a couple of forums located in the UK and there, electric power steering seems to be a very common swap.
Also this site came up > Street Rod Engineering - Custom Street Rod Suspension Kits < they do front end Mustang II upgrades for more power but likely would have some advice to offer if not the parts you need.
It looks like a Prius steering rack is a common swap (Prius - go figure)
> Electric Power Steering Increases Horsepower and Saves Fuel <
Please keep us posted - sounds fascinating! Oh and if you have a minute we'd love to see pictures.
:cheers:
Bayless
Yes, pictures please. Mets are really interesting cars and we see so few of them.
PAUL161
We had 2 of them for the boys when they were in high school. The ones we had were in very nice shape and didn't seem hard to steer at all. Sold the pair of them when the boys graduated, nice little cars. (y)
B
buicfrank
Wife is short. Got a smaller wheel installed. Helped but still hard. I was thinking of power steering before I rebuild the steering. With the engine installed rebuilding the steering will be more difficult. Frank
LarryK
Might try a steering column out of a small KIA that has electric steering assist. Mount unseen under dash and wire to ignition. Friend of mine is working this on a 56 Chevy 6 cyl. Unit used is $150 rather than $2K bought.
algot1901
Bronze
Had a Met and it does not need power
LarryK
These old steering boxes generally could be cleaned and topped with fresh fluid. The older cars had big steering wheels to overcome the turns. Always keep car moving while turning and parking. I, personally, would want to feel the steering before and final guidance. If all the suspension is loose or renewed, most these low horsepower cars are not real tight. Might try to contact a local club mechanic and have them feel it out.
LarryK
Another club forum, ask questions.
algot1901
Bronze
If it were me I would ask join the crowd and ask a question
algot1901
Bronze
I am curious as to why you need power steering they drove just fine without power once you start playing with conversions you do open one large can of maggots I am putting together a prefect and I have no intentions of adding anything besides the engine would not be able to supply enough power to run a pump
Guido36 Electric Power Steering Austin Healey 2
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
R TR2/3/3A Power Steering Triumph 2
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
M TR6 EZ Power Assisted Steering Column Fitment Triumph 3
M TR6 Power Steering Rack & Pinion. Triumph 3
S Power Steering Austin Healey 3
exfed12825 General Tech Electric Power Steering With Fail Safe MG 0
Lin EZ Electric Power Steering Austin Healey 8
mailbox Ford power steering pump Other Cars 0
HealeyRick Power Steering? Austin Healey 1
JodyFKerr Power Steering refurbishment Triumph 12
M Had trouble with Prestone Power Steering Fluid? Jaguar 2
GBRandy Wedge Power Steering flush & Prime [TR8] Triumph 2
GBRandy Wedge TR8 Power Steering Rack is Out! Triumph 24
7 power steering help needed Other Cars 1
GBRandy Wedge TR8 Power Steering Tubes - available soon Triumph 5
SCguy Leaking power steering pump Triumph 5
Jagboy69 E-type Series II Power Steering Pump Jaguar 0
GT6_Mark 280i Manual to Power Steering Conversion TVR 17
D XKE Power Steering Jaguar 4
PATR8 Wedge TR8 Power Steering help Triumph 24
T Wedge Cool! Now the TR8 power steering has croaked Triumph 6
T Power steering leak Jaguar 4
healeyneil Power steering Austin Healey 7
T USB and Auxiliary Power Connections Austin Healey 6
RJS TR4/4A Power (+) Sources Triumph 7
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Eeffoc TR4/4A Out of the blue - started to loose power Triumph 17
H Loss of Power Upon Acceleration Austin Healey 8
JPSmit Power Pack Restoration & Tools 9
billspohn Engine Swapping for Straight 6 Power Other Cars 3
I Bugeye lack of power Spridgets 1
Russ80MGB MGB 1980 MGB - No power MG 16
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
AngliaGT Olds,Power Wagon Spotted 1
Robert Somma power window installation TVR 3
B Intermittent Loss of Electric Power Austin Healey 18
H MGB 1980 mgb no power from ignition switch MG 23
M Power Loss Austin Healey 27
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
C MGA Where to tap into 12v for a power outlet MG 2
G Power to relays Austin Healey 10
M BN1 Loss of Power Austin Healey 21
M TR6 Adding Some Power Triumph 8
nevets interesting article about converting classic cars to electric power Austin Healey 7
S Positive Ground to Negative Ground Power Inverter Austin Healey 11
jfarris TR2/3/3A Loss of Power - ride of shame on flatbed to the house Triumph 15
UmmYeahOk GT6 Zero acceleration power / Car’s RPMs surge when you get in it. Triumph 40
