280i Manual to Power Steering Conversion
GT6_Mark
Building my must do and nice to do lists for my recently acquired '86 280i. One of the nice to dos I am thinking about is a power steering conversion. Anyone done this and able to offer some advice - parts sources/installation tips etc?
It looks like the manual rack on the car is a European Ford part from a Cortina. If so, it seems like a Pinto rack could be a candidate. Does this make sense?
Thanks.
GT6_Mark
GT6_Mark
Surprised that nobody has any thoughts/ideas/advice to share on on this topic.
Why would you want power steering? Is there a lot of effort involved in steering a 280i? Seems like a lot of added weight/complexity and HP robbing PS pump to replace the manual rack if it is sufficient.
GT6_Mark
GT6_Mark
Some 280is came with power steering. The steering is very heavy at low speeds and not convenient for in-town daily driving. Robbing a few horsepower, when there's plenty enough anyway, is less a concern than having a decent daily driver. A conversion looks to be a piece of cake, there is easy access to the rack and it should be possible to source stock Fords bits to complete the work if I can get a pointer on where to start.
Grady
Member
I spent some time fighting with a vibration in my front end. It turned out to be an invisibly warped set of rims but along the way I discovered how much "feedback" shimmies up to the steering wheel.
In addition to boosting the very slow speed turning - which on my 280 with wider and lower tires is a bear - P/S would dampen out the kick-back from every grove and bump in the road. I'd say a plus.
The trick would be to boost the low speed turning, add some dampening and not boost the mid to fast steering. No idea if that's easy or hard.
Also I can't image a Pinto would make a sophisticated donor unit. IIRC, the un-boosted Pinto was pretty hard to turn - too much for my mother who was looking at a new '73(?) wagon and the one with p/s was typically over-boosted (2 finger steering) at all speeds. If my memory is wrong - apologies to all Pinto owners.
It's low on my list of upgrades but might be interested if it worked. Grady
GT6_Mark
GT6_Mark
This job is not high on my list of things to do, but it looks like it would be easy. The rack is simple to access and there is plenty of room at the front of the engine for pulley/pump.
Without power steering the low speed load is too much for my wife to handle, and I get less negative feedback from having toys if she gets to play with them as well.
Therefore, if I can source parts, it would move right up the "to do" list.
I'm just stabbing at the Pinto rack being an option. The European Cortina looks to be the basis for much of the TVR's front end and in my mind this translates to Pinto. Certainly, the rack is not very wide.
Someone must know what power rack the factory fitted.........
Grady
Member
Have you asked on the Wedge Forum? https://www.pistonheads.com/gassing/forum.asp?f=12&h=0
Not to belabor the point, but I'd be concerned about over-boosting and loosing the tight steering at speed.
I think the amount of boost is generally not variable. Its been reduced form the over-boost of the '60-'70 to give a more "European feel". But thinking of my newer cars (a Jag and and US SUV) the steering effort is not noticeably affected by speed.
I recall variable effort being an innovation in Corvettes at some time in the not too distant past - maybe in conjunction with an electric pump?
I agree there should be enough space. Maybe a hot-rod shop could give you some guidance on sourcing modern parts. Grady
Grady
Member
One other thought...
I recall that some BL racks (Spitfires or MGBs?) would gunk up and slowly get stiffer and stiffer. Disassembling and cleaning made a huge and better difference.
Again, no idea if that would apply to our racks. Grady
mrtvr
I happen to have one of the US-spec 280is that was fitted at the factorywith PAS (power assisted steering). I also have one with manual steering. I had driven a 1983 Tasmin for 15 years with manual steering and the feel at low speed was directly proportional with the size of tires you had on the car. The wider the tire the harder the steering effort. I found the lightest feel tended to come with a 195 series tire.
My PAS fitted 1987 gives a nice assist at low speed but you barely feel the difference at highway speed. It's definitely not over-assisted by any means.
My 1984 is currently fitted with 195 series tires and is not a handful at all to drive with the manual steering. I guess it's all in what you are accustomed to.
mrtvr
By the way, to answer the question of what power rack was used on the 280i...all power assisted racks after chassis # FBO19415, was a Supra/TVR rack, according to documentation....this would mean any of the series 2 cars in the States were probably fitted with this rack, apparently with some modifications by TVR. But, don't forget, with TVR nothing is cast in stone and cars vary based on what was available at the time of production. Not that many US cars came in with PAS, perhaps only a couple of dozen series 2s. In the home market, prior to the Toyota unit, TVR used both a Ford sourced and Rover sourced PAS unit.
GT6_Mark
GT6_Mark
Grady, thanks for the idea of checking the current rack for gunk. I want to replace the gaiters/boots anyway, so I might as well pull the rack off while I have it on my lift this weekend.
Marshall, this is intended to be a regular driver for me so I'll give up some feel for convenience. I have a Capri 2.8i PAS pump/bracket along with a bunch of other "collectible" stuff that will get shipped here in a month or so. It will be interesting to see if this works, and the timing also gives me time to hunt down a Supra power rack. My guess is that this will be a project for October.
I'll report back on how this shapes up.
Grady
Member
Mark - Let me know if the gunk check does any good.
Marshall - I'm sure you're right about tire size - I think mine are 245s so it's a pair of huge patches to turn at slow speed. Guess it's too late to complain to the seller <grin>.
Grady
TXCoyote
Haven't visited in awhile but I will chime in here. According to Steve Heath you could have either A/C or PAS with a Tasmin in the US. Most owners chose A/C with only a handful of cars coosing PAS.
Marshall is definitely correct in tire size. Bigger is definitely not better. Ideal sie for the front is 195/65 or 195/70. Steering is easier and handling is much better. My car had 205's when I got it and it wouldn't turn at all. With 195's I can almost turn the wheel one handed at a crawl.
Also, with the anemic Ford lump, you don't want to lose any more power than you have to.
mrtvr
Russ,
Regarding the choice of either A/C or PAS here in the states, I believe your statement is correct regarding Series 1 and 1.5 cars with the upright radiator just in front of the engine. However, with the Series 2 cars with the nosecone radiator, things changed with all the extra space available. My 1987 came from the factory with both A/C and PAS. Also, I believe all wedges that came to the States were fitted with A/C. I could be wrong, but I believe that to be the case.
Marshall
GT6_Mark
GT6_Mark
I have 205/60's, so 195/65 or /70s might be a real alternative option as re-tiring is something that I want to do later this year anyway. I'll get some "temporary" 195s mounted to see if this is the way to go.
Anyway, it looks like I have tracked down all the parts I need to do the power conversion - full front end from someone parting out an '84 Supra here locally and two PS pumps/brackets - one from a Euro Capri 2.8i the other from a Euro Granada 2.8i - in the UK (along with a 5-speed transmission.) This stuff will need overhauling, so the PS project is going to slip down my to-do list. It's looking like November/December time frame.
I'll report back on progress or any other findings.
TXCoyote
mrtvr said:
Russ,
Marshall
You may be right Marshall, I was just quoting from the book. I don't think he differentiated the different series.
As for PAS, it would be nice but I would only do mine if I found a rackk that I could get replacement parts for. Toyota sounds good, I look forward to seeing what Mark comes up with on that.
mrtvr
Some additional information about the steering racks TVR used, in a conversation with Steve Heath recently, he told me the 'Supra' racks were made by a company called Supra, not taken from a Toyota Supra. I don't know if the Supra company is still in existence. As I have a couple of customers very intent on doing a PAS conversion, I am working on a couple of other leads and will report as I find out how they pan out.
R For Sale Nice TVR 280i For Sale Other British Classifieds 6
J 1985 TVR 280i Speedometer Cable TVR 4
H 280i oil filter TVR 2
G Triple Weber DCNFs on 280i V6? TVR 1
S 280I parts? TVR 0
Feathers 280I radiator TVR 5
H 280i Tires TVR 7
M FOR SALE: 280i 2.8 v6 engine and 4 speed transmission for sale TVR 2
A 1985 280i - stalls when warm TVR 6
J Just purchased an 84 280i from the UK TVR 15
tr7andtvr 280i Rear End 4.20? TVR 0
tr7andtvr 280I weather strip source TVR 1
tr7andtvr carpet pad? 280i TVR 3
tr7andtvr headlight upgrade 280i TVR 4
tr7andtvr 280i seat swap? TVR 8
tr7andtvr 280i Ford 302 Conversion TVR 22
Sparkie New 5 speed conversion for 280i guys TVR 32
tr7andtvr 280i engine conversion? TVR 1
tr7andtvr 280i For Sale [before I put it on ebay] $6500.00 TVR 1
tr7andtvr who knows anything about this 280i on ebay? TVR 2
G 280I/ TASMIN HEADLIGHTS TVR 4
T 280i auction sale Other British Cars 8
H Hey Hayfever, 280i in Austin on EBAY Other British Cars 1
T 1985 TVR 280i Other British Cars 14
H TVR 280i Other British Cars 14
drustom Service or Owner's Manual? Jaguar 1
prb51 Bentley Manual Austin Healey 3
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
Michael Oritt Smitty's Five-Speed Manual Austin Healey 1
C For Sale Parts, Factory Manual, Restoration Guide for 1959 100-6 Austin Healey Classifieds 4
humanoid For Sale - Haynes Trimumph TR7 (1975-1981) Automotive Repair Manual Triumph Classifieds 0
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S For Sale Triumph TR250 Factory Workshop Service Manual on CD/ROM – 1968 Models Triumph Classifieds 0
S For Sale Aston Martin DB6 Factory Parts Manual on CD/ROM – 1965 - 1971 Models. Other British Classifieds 0
S For Sale Triumph TR5 Factory Parts Manual on CD/ROM - 1967 to 1968. Triumph Classifieds 0
S For Sale MG TD Factory Parts Manual on CD/ROM MG Classifieds 0
S For Sale MG TF Factory Parts Manual on CD/ROM MG Classifieds 0
S For Sale Austin Healey 100-4 Factory Parts Manual on CD/ROM Austin Healey Classifieds 0
S For Sale MG MGB Factory Parts Manual on CD/ROM - 1962 - 1976 Models MG Classifieds 0
S For Sale Austin Healey Bugeye Sprite MK 1 Factory Workshop Manual on CD/ROM Austin Healey Classifieds 0
S For Sale Triumph TR5 Factory Workshop Manual on CD/ROM - 1967 - 1968 Models. Triumph Classifieds 0
S For Sale Aston Martin DBS V8 Factory Workshop Manual – 1967 - 1972 Models. Other British Classifieds 0
S For Sale Aston Martin DB6 Factory Workshop Manual on CD/ROM – 1965 - 1971 Models. Other British Classifieds 0
S For Sale Sunbeam Alpine Factory Workshop Manual - All Models 1959 - 1968 Other British Classifieds 0
S For Sale Austin Healey 100-4 Factory Workshop Manual on CD/ROM Austin Healey Classifieds 0
S For Sale Jensen Interceptor and FF Factory Workshop Manual on CD-ROM Other British Classifieds 0
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
S For Sale Triumph GT6 Workshop Manual on CD/ROM – 1966 through 1973 Models Triumph Classifieds 0
S For Sale Triumph TR6 Workshop Manual on CD/ROM - 1969 - 1976 Triumph Classifieds 0
