280i engine conversion?
tr7andtvr
My 280i that was on eBay started a knocking sound shortly after a local test drove it.....
1. Has anyone on here ever swapped to another Ford V6? (3.8 or 4.0) Is it as easy as it looks? I guess it would make since to get the 5 speed also?
2. What would this do to resale?
Sparkie
It's said that Trevor wouldn't mind... It's such a personal preference for car guys; there's one school that likes stock and others who like more modern/powerful power plants...
Personally I prefer the power, but I hot rod everything I touch. My 280i is getting a 4.0 soon, so I have been researching options recently. I will be posting soon on a new 5 speed transmission that's now a bolt-in to our engines.
Some random thoughts: The bolt in 5 speed for Euro Tasmin's was the Ford type 9 (or type N). It has been around for a while (Capri's and Sierra's), but there are a lot more available in the UK than the US.
Engine: all of the Cologne engines will bolt up (2.8, 2.9, 3.1, 4.0), even the SOHC 4.0 has the same bell housing pattern. The 3.8L is not a Cologne engine and I am sure the bolt pattern is different. The issues will be exhaust and induction.
The 2.8L in our TVR's has two exhaust ports per head, not three as in all US Cologne engines. So there's an exhaust plumbing project here.
The US never used anything but injection, but Offenhouser does make a US 2.8L version for a 2 or 4 BBL should you consider a US 2.8L. They also make an un-advertised intake for our Euro 2.8L but that costs approx $500 (the intake ports are in different locations between US and Euro 2.8L). Also, the Euro 2.8L intake (with your current injection) will not fit any of the US engines. Your choice of induction with a US engine would be either a complete US ECU/wiring loom or drive the injectors with something like a Haltech or Megasquirt - some tuning (programming) to do here. I will be doing this soon, but perhaps not soon enough for you.
I have concerns about fitting some of the newer US engines under the hood (with their stock intakes so high and off center due to the long runners coming out of the center valley and bending to the side where the plenum resides). I have not had time to measure the newer US intake heights - they look to be taller than our Plenum. I have the parts, just haven't had time to measure. I'll be fabbing my own to mimic the stock plenum so I can adjust for height...
It may be easier to rebuild the original engine. Parts are available and the engine is pretty straight forward.
M FOR SALE: 280i 2.8 v6 engine and 4 speed transmission for sale TVR 2
R For Sale Nice TVR 280i For Sale Other British Classifieds 6
J 1985 TVR 280i Speedometer Cable TVR 4
H 280i oil filter TVR 2
G Triple Weber DCNFs on 280i V6? TVR 1
S 280I parts? TVR 0
Feathers 280I radiator TVR 5
H 280i Tires TVR 7
A 1985 280i - stalls when warm TVR 6
J Just purchased an 84 280i from the UK TVR 15
tr7andtvr 280i Rear End 4.20? TVR 0
tr7andtvr 280I weather strip source TVR 1
tr7andtvr carpet pad? 280i TVR 3
tr7andtvr headlight upgrade 280i TVR 4
tr7andtvr 280i seat swap? TVR 8
GT6_Mark 280i Manual to Power Steering Conversion TVR 17
tr7andtvr 280i Ford 302 Conversion TVR 22
Sparkie New 5 speed conversion for 280i guys TVR 32
tr7andtvr 280i For Sale [before I put it on ebay] $6500.00 TVR 1
tr7andtvr who knows anything about this 280i on ebay? TVR 2
G 280I/ TASMIN HEADLIGHTS TVR 4
T 280i auction sale Other British Cars 8
H Hey Hayfever, 280i in Austin on EBAY Other British Cars 1
T 1985 TVR 280i Other British Cars 14
H TVR 280i Other British Cars 14
mctriumph For Sale Tr7 engine Triumph Classifieds 0
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
